Noob Swap Question
Old May 1, 2007 | 05:42 PM
DenzComp's Avatar
Default Noob Swap Question
I have a 91 standard all stock hatch right now...I can get a free D16A6 motor with about 60,000 miles on it.
How hard of a swap will this be? Will it just hook right up with the old mounts? What all is needed?
I'm new to the whole "honda scene"
Thanks for any info...I am mechanically inclined to a point, I just have never done a motor swap.....Sorry if this is a dumb question.
Thanks again,
-Dennis
Old May 1, 2007 | 05:49 PM
julioboostamante's Avatar
Default Re: Noob Swap Question (DenzComp)
if you are already MPFI then just drop in the A6, in not the drop the motor in and then do the conversion while your swapping the motor. its not hard. \\good luck!
Old May 1, 2007 | 05:51 PM
DenzComp's Avatar
Yeah, it is MPFI. So this is a fairly easy swap?
I know it isn't that much of an upgrade from the D15, but it has way less miles and a bit more HP.
Old May 1, 2007 | 05:55 PM
the1337couch's Avatar
yeah it will bolt right up
Old May 1, 2007 | 05:58 PM
C1CRX's Avatar
Traffic signal tech
Default Re: (the1337couch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the1337couch &raquo;</TD></TR><TR><TD CLASS="quote">yeah it will bolt right up </TD></TR></TABLE>
bolt right up yes but you will still have to do the wiring to convert to mpfi add some wiring which isn't too hard but can be challenging check the FAQs.
Old May 1, 2007 | 06:03 PM
DenzComp's Avatar
I thought since I all ready had MPFI then I'd be fine.
Old May 1, 2007 | 07:19 PM
blinger's Avatar
Default Re: (DenzComp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DenzComp &raquo;</TD></TR><TR><TD CLASS="quote">I thought since I all ready had MPFI then I'd be fine.</TD></TR></TABLE>it is
fuzzysig
K Series
Dec 8, 2017 08:26 PM
PR_purpleDb7
Oct 16, 2008 02:11 PM
nicrom
Honda Motorcycles
Dec 27, 2005 05:43 PM
paidroe454
Jul 10, 2004 07:32 PM
SupraMustang
May 15, 2004 07:34 PM
