help with d16z6 swap into 90 si
Old May 1, 2007 | 05:32 PM
89efhatchy's Avatar
Default help with d16z6 swap into 90 si
I've searched but want to make sure of a few things. The motor is being built before it goes in so it will be a while but I still wanted to get some of this in my mind first. I plan to go with a rywire obd0 to obd1 harness and run a p28 and the z6 distributor. What I was curious about, will I have to use the a6 intake manifold or can I use the z6 manifold and all the sensors? Or maybe the z6 manifold with sensors off the a6 if needed? Wasnt sure what all interchanged. Id appreciate any help!
Old May 1, 2007 | 05:51 PM
danmdevries's Avatar
Default Re: help with d16z6 swap into 90 si (89efhatchy)
If you're going obd 1 it's nice n easy to just use a z6 mani and throttlebody.
It lets you pull that firewall mounted map sensor off as the new map is on the tb
You can use either one though.
Old May 1, 2007 | 06:51 PM
89efhatchy's Avatar
Default Re: help with d16z6 swap into 90 si (danmdevries)
sweet,I was hoping that would be the case.
55superbeetle
Jun 12, 2007 06:14 AM
4DRmafia
19
Mar 4, 2006 06:11 PM
AJxr
10
Dec 18, 2005 04:08 PM
smithbling
May 1, 2003 05:16 AM
SOUTHCREX
Nov 18, 2002 06:03 PM
