ep3 foglights
Old May 1, 2007 | 04:54 PM
joey funk's Avatar
Default ep3 foglights
i just purchased some foglights and i need some advice on how to install them, thanks
Old May 1, 2007 | 05:41 PM
HBK_DAVIDDD's Avatar
Default Re: ep3 foglights (joey funk)
there are markings on the back of your bumper where you cut with a dremel tool or a utility knife. then assemble the brackets with the housing and the screws into the tabs that hold on the foglight
Old May 2, 2007 | 07:11 AM
T_Virus's Avatar
Where did you buy them from? Ebay? ALso check with EPhatch.com and search for fog light install...They have it there...
Old May 2, 2007 | 12:40 PM
madcityEP's Avatar
if you go to a dealer they can print you off some infor for you.
Old May 3, 2007 | 08:35 AM
BarracksSi's Avatar
Default Re: ep3 foglights (nighthawkep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighthawkep3 &raquo;</TD></TR><TR><TD CLASS="quote">if you go to a dealer they can print you off some infor for you.</TD></TR></TABLE>
Or, you can also go to http://www.handaaccessories.com/civicsi.html and check out the PDF of the factory foglight installation instructions.
However, if you're going to be doing your own wiring, those instructions won't help with that part. The OEM foglights come with wiring harnesses & plugs that add into the car's main harness. But, at least you'll get an idea of where to route your wires and how to remove the bumper and other panels.
bpr0422
19
Nov 10, 2010 11:43 PM
eL
Honda Fit
Jun 21, 2008 08:36 PM
cb7tougeracer
May 19, 2007 01:23 PM
invisible
12
Oct 19, 2006 10:45 AM
HIboost
Feb 12, 2006 01:19 PM
