sunroof in an EK?
Old May 1, 2007 | 04:23 PM
ek9tl's Avatar
Default sunroof in an EK?
Hey guys im thinking of puttin a sunroof in my EK hatch. I have a DX. I heard lots of ppl say it might leak if not done right. Has anyone ever done this? Any pointers?
Old May 1, 2007 | 05:10 PM
ridin98civic's Avatar
Default Re: sunroof in an EK? (ek9tl)
depends, i have seen quality sunroof installs that didnt leak even after years of use, and i have seen some that leak from day 1
Old May 16, 2007 | 03:03 PM
drift_n_shift's Avatar
From: Off the Florida Keys, in a place called Kokomo, USA
Default Re: sunroof in an EK? (ridin98civic)
i am thinking about buying an ek and doing the same. how much structural rigidity will you loose?
also, does any one know whether in the factory, say you have a 96-00 coupe, they just weld in the sunroof roof for cars with it, and the solid ones for ones that don't, or is there additional support?
Modified by drift_n_shift at 7:17 PM 5/16/2007
Old May 16, 2007 | 04:30 PM
00whiteek's Avatar
good luck with putting a sunroof in your car
Old May 16, 2007 | 04:39 PM
ekb16's Avatar
my cousins ek hatch had one put in...it was put in b4 they bought the car tho but it was really nice..didnt leak or nething
Old May 20, 2007 | 12:22 AM
NOFX's Avatar
H-T White Ops
Default Re: sunroof in an EK? (drift_n_shift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_n_shift &raquo;</TD></TR><TR><TD CLASS="quote">i am thinking about buying an ek and doing the same. how much structural rigidity will you loose?
Modified by drift_n_shift at 7:17 PM 5/16/2007</TD></TR></TABLE>
I believe I told you this in an IM.
The moonroof is not welded into the roof. It is a fully different panel. There is one part numebr for the Civic coupe roof without a moonroof and another part number for the Civic coupe roof with a moonroof. That's just for the roof skin. The cars with stock moonroofs don't just have a raw hole cut into them, instead they have a smooth, bent surround that dips into the moonroof hole.
An aftermarket moonroof will have the seal around the metal piece. An OEM moonroof will have the rubber seal around the glass instead.
And I agree with ridin98civic. It does seem almost hit and miss on if it will be a decent install. Perhaps if you choose to have an aftermarket unit put in, you could ask to see examples of the installer's previous work.
Old May 20, 2007 | 01:22 AM
Team RS2's Avatar
Default Re: sunroof in an EK? (NOFX)
actually its pretty easy we had one in our truck, and my neighbor as one in his truck, it uaslly is a manual pop up or electric rag top, dosnt cost much
Old May 20, 2007 | 01:54 AM
NOFX's Avatar
H-T White Ops
Oh, and to clarify, my reply to drift_n_shift was in reference to OEM moonroofs. After that I continue on talking about aftermarket units.
Old May 20, 2007 | 02:08 AM
ahhsimon's Avatar
Default Re: (NOFX)
i have a whole gsr sunroof assembly i was thinking about putting in my hatch, but labor and crap seems a lil high besides that they say it may leak but i have everysingle thing but yeah the rubber is on the glass and not the roof .. hmm -_- but there is a draining cover and tubes for the sunroof so doesnt that help the leak ?
Old May 20, 2007 | 04:36 AM
Bullitt's Avatar
Default Re: (ahhsimon)
Don´t you had the moonroof as a factory option for the ek hatchbacks?
My Hatchback came with a factory moonroof, but I´m from Germany. So I don´t know about the US models.
Old May 20, 2007 | 05:21 AM
Ramma's Avatar
good luck
Old May 20, 2007 | 05:34 AM
. a d a m's Avatar
Default Re: (Bullitt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bullitt &raquo;</TD></TR><TR><TD CLASS="quote">Don´t you had the moonroof as a factory option for the ek hatchbacks?
My Hatchback came with a factory moonroof, but I´m from Germany. So I don´t know about the US models.</TD></TR></TABLE>
It was not an option on US models.
Old May 20, 2007 | 05:42 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (. a d a m)
Bottom line do research on the place you go to. I want one in my ej6 eventually, but I'm going to a top dollar place because I know that the extra few hundred dollars is money well spent if it doesn't leak.
Structuall rigidity won't be an issue. But top heavy-ness might for tracking. But for most weekend warriors it wont be an issue.
Old May 20, 2007 | 11:15 AM
NOFX's Avatar
H-T White Ops
Default Re: (ek forever guy)
In the US the hatch models (CX and DX) didn't have available moonroofs. The EX and Si coupes did though and so did the EX sedan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Bottom line do research on the place you go to. I want one in my ej6 eventually, but I'm going to a top dollar place because I know that the extra few hundred dollars is money well spent if it doesn't leak.
Structuall rigidity won't be an issue. But top heavy-ness might for tracking. But for most weekend warriors it wont be an issue.</TD></TR></TABLE>
I actually heard from one installer (he's been installing for decades) that it can help the car be more rigid. I can see who that can be though. The roofs with moonroofs don't have any less roof bars than the roofs without moonroofs and the edge of the moonroof could count as more support across the top of the car.
Old May 20, 2007 | 03:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
The moonroof is not welded into the roof. It is a fully different panel. There is one part numebr for the Civic coupe roof without a moonroof and another part number for the Civic coupe roof with a moonroof. That's just for the roof skin. The cars with stock moonroofs don't just have a raw hole cut into them, instead they have a smooth, bent surround that dips into the moonroof hole.</TD></TR></TABLE>
yea i sent you the IM after I posted this. I think im going to try and get the measurements for the size of the roof panel for a ek and em1 and see if they are the same. hopefully they will be, so i can just get the new panels from honda or one from a wrecked em1 (or ex etc.)
Old May 20, 2007 | 03:50 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">I actually heard from one installer (he's been installing for decades) that it can help the car be more rigid. I can see who that can be though. The roofs with moonroofs don't have any less roof bars than the roofs without moonroofs and the edge of the moonroof could count as more support across the top of the car.</TD></TR></TABLE>
I've heard the exact same thing on several occasions. It makes sense but I haven't delved into any of the technicalities of it. I can't see how it would "dramatically weaken it"
The only thing I'd worry about as far as performance is drag and/or adding weight to the top most point of the car which can possibly affect cornering.
Old May 20, 2007 | 03:51 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_n_shift &raquo;</TD></TR><TR><TD CLASS="quote">yea i sent you the IM after I posted this. I think im going to try and get the measurements for the size of the roof panel for a ek and em1 and see if they are the same. hopefully they will be, so i can just get the new panels from honda or one from a wrecked em1 (or ex etc.) </TD></TR></TABLE>
I can tell you they're not. The coupe is much shorter in legth. I have both a coupe and hatch in my garage. The coupe's roof is way too short to put it on the hatch.
Old May 20, 2007 | 03:54 PM
NOFX's Avatar
H-T White Ops
Default Re: sunroof in an EK? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I've heard the exact same thing on several occasions. It makes sense but I haven't delved into any of the technicalities of it. I can't see how it would "dramatically weaken it"
The only thing I'd worry about as far as performance is drag and/or adding weight to the top most point of the car which can possibly affect cornering.</TD></TR></TABLE>
That's what I've thought of too. The added weight... I wish I knew how much it all was.
Plus I know for at least some sorts of racing they might require you to block it or tape it off or something.
I personally would not put a moonroof on a coupe or sedan. The hatch would be the only body style I'd ever even think of it since they didn't have them in the US. And then I'd still want an OEM roof... so I'd see if I could collect the roof skin and headliner from elsewhere. I believe (I can check later) that the coupe/sedan moonroof internals and the hatch moonroof internals are the same.
Old May 20, 2007 | 09:00 PM
I can tell you they're not. The coupe is much shorter in legth. I have both a coupe and hatch in my garage. The coupe's roof is way too short to put it on the hatch.</TD></TR></TABLE>
EXPLETIVE!!!!
off to europe or japan to get an oem ek one i suppose lol
although you haven't done it yourself, just to confirm about what i asked in pm nofx, a good idea would be to cut the whole roof panel off, and weld a new one in correct? for example, this pic from ES3
Modified by drift_n_shift at 1:18 AM 5/21/2007
Modified by drift_n_shift at 1:19 AM 5/21/2007
Old May 20, 2007 | 10:08 PM
SoullessJapaneseMachine's Avatar
do a whole-roof sunroof
Old May 25, 2007 | 08:27 AM
OG SHG_EM1's Avatar
i have a 99 ek sunroof for sale if anyone wants to put it in there car...the entire assembly with harness and switch...
Old May 25, 2007 | 08:56 AM
.:Swig:.'s Avatar
pretty sure you can use a sunroof from an ex
edit: go rag top.. jk
Old May 25, 2007 | 12:06 PM
NOFX's Avatar
H-T White Ops
Well, looks like the EDM part numbers for the coupe and hatch moonroof assemblies are different. I'm not sure if that means it won't work... but there's a chance.
There might be an inssue in the way the coupe's roofline arches, which the hatch does not.
I'll measure the coupe and hatch roof gutters here for a roof length if someone will do the same for a sedan. Right now I'm thinking the sedan will be a better candidate for parts perhaps.
Maybe the roof of the sedan will even be about the same size, which could lead to having the roof skin and headliner come from the sedan to be used on a hatch. Maybe a little trimming and then it'll fit?
Old May 25, 2007 | 12:34 PM
rpared01's Avatar
Will the 99 or 2000 si sun roof work in a 97 hatchback ?
Old May 25, 2007 | 12:37 PM
kaoss_11's Avatar
B A N N E D
My roommate had one on his it was from an SI
