has anyone else had there rsx throw a trouble shoot code like mine
Old May 1, 2007 | 03:51 PM
typesnick's Avatar
Default has anyone else had there rsx throw a trouble shoot code like mine
Ok my car is throwing to codes P1166 which is air fuel ratio (A/F) snesor heater circut malfunction and the other is P1167 which is air fuel ratio (A/F) sensor heater system maulfunction if so how was you able to fix it?
Old May 1, 2007 | 04:05 PM
AcuraTech23's Avatar
Default Re: has anyone else had there rsx throw a trouble shoot code like mine (typesnick)
OK, THAT CODE IS FOR THE REAR O2 SENSOR WHICH THE WHITE ONE IN THE MIDDLE OF THE CATALYST CONVERTOR. THE PRIMARY O2 SENSOR IS GREEN AND THE WIRING IS SHORTER. WHITE OR GREEN MEAN THE INSULATOR COVERING THE O2 SENSOR WIRINGS. I HAVE SEEN A FEW OF THEM GONE BAD, IT ALMOST A COMMON PROBLEM WITH THE 02-06 RSX. IT EXPENSIVE NEW SO TRY TO ASK AROUND IF ANYONE HAS ONE SELLING USED.
Old Feb 4, 2008 | 09:28 AM
pearlteg's Avatar
I HAVE AN 02 RSX AND ITS ALSO GIVING ME CODES P1167 AND P1166... ALSO MY HEATER IS NOT WORKING.... WHAT ENDED UP BEING UR PROBLEM
DJSAL
Jul 27, 2010 03:05 PM
Jon at Titan
Dec 6, 2006 06:30 PM
EG35PSI
Oct 4, 2006 07:08 PM
-KangaRod-
Jan 19, 2005 08:16 AM
