Will this swap work?
Old May 1, 2007 | 02:50 PM
danny-mcar's Avatar
Default Will this swap work?
JDM Honda Civic CRX ENGINE D15B OBD1 non-vtec motor in a 91 crx hf. Also will this block bolt up to an SI Transmission
Old May 1, 2007 | 02:58 PM
Slurp56's Avatar
Default Re: Will this swap work? (danny-mcar)
Sure, it will work just fine if you convert to OBD1 and run the correct ECU. Yes, the tranny will bolt up.
Old May 1, 2007 | 03:02 PM
danny-mcar's Avatar
Default Re: Will this swap work? (Slurp56)
WHAT WOULD I HAVE TO DO TO CONVERT TO OBD1?
Old May 1, 2007 | 03:09 PM
EFart's Avatar
WHATS WITH THE CAPS!?
Slurp56's Avatar
Get an OBD1 ECU and an OBD0 -> OBD1 jumper harness. If the ecu requires a 4 wire O2 sensor, then you'll need to wire that in too.
Old May 1, 2007 | 03:41 PM
danny-mcar's Avatar
THANKS FOR EXPLAINING IT FOR ME. ILL BE LOOKING FOR THE OBD1 ECU AND THE CONVERTER AND ILL CHECK TO SEE IF THE O2 SENSOR HAS 4 WIRES.
THANKS AGAIN ,
Old May 1, 2007 | 03:49 PM
danny-mcar's Avatar
Default Re: (EFart)
IM ON A TRIAL PERIOD. MEANING IM WASTING THIS 1 OF 5 ENTRIES ON YOU. I DIDNT THINK THE CAPS WOULD OFFEND YOU BUDDY. I'D LIKE TO PUT ALL MY TIME INTO MY CAR AND NOT YOU!
Ash J. Williams
Nov 18, 2012 08:39 AM
tdubbebawllin
Mar 1, 2009 07:57 PM
jdmboi3278
Engine Management and Tuning
Jan 28, 2009 11:17 PM
v8Buster
Oct 23, 2006 06:04 PM
hatchyboy89
Apr 5, 2005 10:20 AM
