B18 CRX Swap Help . Reward Offered.
Old May 1, 2007 | 09:40 AM
MugenCRX89's Avatar
Default B18 CRX Swap Help . Reward Offered.
We have the engine bolted in and kinda hooked up, but we need some help.
I need to get a diagram of the fuel injector wiring.
Also do you guys know why the ecu wont turn on? we can turn the key and the cluster works and when we turn the key something clicks like its trying to start.
and i would like the vacume wiring diagram.
heres some pics.
please identify these
10 dollers on paypal is the reward
Old May 1, 2007 | 09:58 AM
turbostd's Avatar
Default Re: B18 CRX Swap Help . Reward Offered. (MugenCRX89)
What motor harness are you using?
Old May 1, 2007 | 10:35 AM
CW-ITR's Avatar
Default Re: B18 CRX Swap Help . Reward Offered. (turbostd)
The engine harness doesn't look like an DPFI harness. Therfore, lots of modification will need to be done to make it run right. Use the original DPFI engine harness (or pull one from the junk yard) and convert it to MPFI follow the instruction found in the sticky search.
Old May 2, 2007 | 05:26 AM
MugenCRX89's Avatar
Default Re: B18 CRX Swap Help . Reward Offered. (CW-ITR)
ok well we found the connector and cut and connected the wires so now thats hooked up.
now the ecu turns on, but stillnothing when we turn the key. is their a wiring diagram for crx b18 swap. and we are using the crx wiring.
Old May 2, 2007 | 05:40 AM
J4k3's Avatar
I haven't been able to find anything on wiring a b18b into a crx. Plenty of crap about a b16 though
komet 163
Sep 27, 2016 04:50 PM
lsvtek
Nov 3, 2008 10:29 PM
harmonator84
Mar 20, 2007 10:20 AM
SteyrTMP
10
May 1, 2005 10:38 PM
