tryin to make the y8 manifold work in obd1 need help
Old May 1, 2007 | 07:03 AM
eg8tuner's Avatar
Default tryin to make the y8 manifold work in obd1 need help
this issue im having it that obd1 requires the IAT sensor and the is no place for one on the y78 manifold what can i do about this.
Old May 1, 2007 | 07:11 AM
suspendedHatch's Avatar
Default Re: tryin to make the y8 manifold work in obd1 need help (eg8tuner)
Drill a hole in your intake pipe, use two long zipties. Cut the head off one ziptie and use it in the other hole on the sensor. You'll also need to extend the sensor wires using some 18 gauge wire, solder, heat shrink, split loom and electric tape.
If you want pics, send paypal
To do the PCV cleanly you'll need to get one from a 96+ Y8. On the later Civics the elbow valve in the breather box is also a PCV.
I asked my homeboy who is an EMS dyno tuner if moving the sensor would have any effect on the fuel calibration. He said the IAT sensors are not a huge factor because they respond so slowly to changes in air temp. Reset your ECU and you're all set.
Old May 1, 2007 | 07:12 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: tryin to make the y8 manifold work in obd1 need help (suspendedHatch)
^^ I get all teary eyed when you visit this forum.
Suspendedhatch FTW.
Old May 2, 2007 | 06:17 AM
eg8tuner's Avatar
im nto really going for clean because this is my auto-x car so could i plant it in the intake tube (much easier to replace if i f up my drilling)
Old May 2, 2007 | 06:19 AM
97Ej6mike's Avatar
the IAT is a useless plug, and it can be left hanging down, and it wont affect the car in any way, but if it bothers you that much, drill a small hole in your intake tube, shove it in tight, and seal it with some gasket sealent on the edges.
LSXFEIND
Mar 16, 2009 01:06 PM
south504
Dec 9, 2008 03:29 PM
6doorsentra
Sep 6, 2006 02:53 PM
EJ2-Fluffy
Jan 15, 2005 01:51 PM
Vince_badaz
Oct 31, 2003 08:35 AM
