Remove rear seats???
Old May 1, 2007 | 06:09 AM
yoffer's Avatar
Banned
Default Remove rear seats???
Trying to install my stereo and i want to know how to remove the back seats out of a 99 civic Coupe.
Old May 1, 2007 | 06:22 AM
pkdog167's Avatar
Default Re: Remove rear seats??? (yoffer)
For the bottom part, there is about four screws, two in the back and two in the front. As for the upper part, you just need to remove the screw that hold the seats. Just try to found all the screws, it's not that hard.
Old May 1, 2007 | 06:25 AM
yoffer's Avatar
Banned
do you know where the screws are located?
Old May 1, 2007 | 08:11 AM
B16b-EJ8's Avatar
Default Re: Remove rear seats??? (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">For the bottom part, there is about four screws, two in the back and two in the front. As for the upper part, you just need to remove the screw that hold the seats. Just try to found all the screws, it's not that hard.</TD></TR></TABLE>
What?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer &raquo;</TD></TR><TR><TD CLASS="quote">Trying to install my stereo and i want to know how to remove the back seats out of a 99 civic Coupe. </TD></TR></TABLE>
OK first pull the bottom cushion out...pretty simple just grab the back of it where it meats the seat back and give it a tug and it will pop right out...then flip the seats forward and you will see i believe 4 10mm bolts under the carpet towards the bottom of the seat back...unbolt these, then slide the smaller half out first....from there you should be able to figure out the rest.
Old May 1, 2007 | 06:40 PM
pkdog167's Avatar
Default Re: Remove rear seats??? (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
What?
lol I was just guessing
TegoDC5
12
Jan 6, 2005 10:12 PM
NewBorn_EG
11
Oct 4, 2004 09:56 AM
imadigitalgod
Oct 1, 2004 07:29 PM
is3oo
Sep 5, 2003 02:52 PM
JL 74
Mar 25, 2002 08:30 PM
