Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Test Pipe
Old Apr 30, 2007 | 10:19 PM
Vermont's Avatar
Default Test Pipe
I know that dezod carrys megan racing test pipes for our car and with my exasut setup i will be needing one this weekend. Only problem im looking at about 160 to get it to me by this weekend. $95 for pipe and $85 for the damn 3 day shipping. Does any one else have either a test pipe for sale or a place where i can get one Pref in a 70mm diamiter(sp?) i gota freind helping me put on my coilovers, brakes and exaust.
For those that have done Coilovers, do i need anything else if i got Tein basics, Honda uppermount, Front and rear camber kits. I plan on taking the car in to a shop to get a correct alignment. Any one else have any suggestions?
I am about to ask the biggest and most retarded question ever but i hoanstly am not certian. When i rotate my tires i take the rear left and move up to the right front and like wise on the other side right?
Thank you all for the help ahead of time.
Old May 1, 2007 | 08:05 AM
bioweapon's Avatar
You have everything you need for the coilover setup.
And for rotating the tires, just go front to back on the same side. Dont worry about going to opposite sides.
Old May 1, 2007 | 08:08 AM
bravo831's Avatar
Default Re: (bioweapon)
yeah dont swithc becouse, well its acording to what tires you have but your tred could be backwards
Old May 1, 2007 | 10:13 AM
Vermont's Avatar
Default Re: (bravo831)
thanks. As for my rubber i got Bridgestone Potenzas. Came stock on the car. I only have 20,000 as of sunday, Also could any one tell me what would cause a vibration at 60-70 mph. Only happens between theese speeds. I have hit my front driver side pretty hard into numerable things so i was thinking it would be in that corner of the car. but what would be giving me this vibration?
Old May 1, 2007 | 10:25 AM
OSK Automotive's Avatar
Default Re: (Vermont)
Get your wheels balanced first to see if the vibration goes away. A long time ago I hit a curb in the winter and my car did the same thing. I freak out and thought something in the suspension was bent. I later found out that my wheel was just out of balance.
dc5itracer
Aug 21, 2011 04:12 PM
Tong.Y
Jan 2, 2011 08:14 AM
jdmisoverrated
Jan 31, 2008 07:54 AM
komat
Apr 5, 2006 09:55 AM
