car's running rich..
Old Apr 30, 2007 | 07:36 PM
SHhh__VTEC's Avatar
Default car's running rich..
I have a 96 jdm R with intake and header. Car is basically stock. Car's been running rich since i bought the car. It's bad to a point that the rear bumper is turning black. I'm wanting do fix all the dents and repaint the whole car but can't really do that until I fix the running rich problem. What are some things I can work on to fix this? I'm also running denso iridium plugs. I forgot the gaps, but would the gap matter? Help!!!
Old Apr 30, 2007 | 07:45 PM
ge_itr's Avatar
Default Re: car's running rich.. (SHhh__VTEC)
you need to tune it...that would also give you better gas mileage
Old Apr 30, 2007 | 08:20 PM
Sfedai0's Avatar
Ive got a even more stock R with just intake, and I still got soot on my bumper.
Old Apr 30, 2007 | 09:04 PM
Loud-N-Clear's Avatar
My 97's bone stock, and it is running very rich as well. To the point where if I wash her,by the time I drive her home, the back looks filthy. I'm taking her in for a full mechanical inspection tommorow, so if there is anything that needs to be fixed besides tuning, I'll let you know what it is.
Old Apr 30, 2007 | 10:05 PM
WickedKP's Avatar
Default Re: car's running rich.. (Loud-N-Clear)
At least i know i'm not the only who has to wipe the rear *** once in a while
Old Apr 30, 2007 | 11:24 PM
actionanh's Avatar
There are just to many variables to the reason why the car is running rich, it can be……………..
- The rings
- Bent vale
- Seals
- Blow by
- Bottom end
- Etc…
Do a compression check and leak down
Old May 1, 2007 | 03:43 AM
SHhh__VTEC's Avatar
I did a compression check already. results are
1- 263
2- 252
3- 264
4- 258
never did a leak down though. I dunno how to do that =/ How do you go by tuning a stock R? What do I use to tune it?
Old May 1, 2007 | 03:53 AM
RTW DC2R's Avatar
are you using a cat?
Old May 1, 2007 | 11:34 AM
Dsee2's Avatar
Default Re: car's running rich.. (RTW DC2R)
Sorry for hijacking the thread, but I have a 2001 R with a jdm 4-1, intake and a sms test pipe. Im having the same problem with my car, any advice? 70,000 miles, and no major tune-up. ???????
Old May 1, 2007 | 12:17 PM
MatrixShark's Avatar
Default Re: car's running rich.. (WickedKP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedKP &raquo;</TD></TR><TR><TD CLASS="quote">At least i know i'm not the only who has to wipe the rear *** once in a while </TD></TR></TABLE>
Sometimes I get a little jealous of the black R's.... This is really just a problem for us yellows and the whites.
Old May 1, 2007 | 12:32 PM
Hooch'n's Avatar
Default Re: car's running rich.. (MatrixShark)
if you have an exhuast aftermarket it makes it worse i've found.
Also, my car has always gotten dirt on the back bumper from the exhuast since the first 8miles.
Just part of having an Integra......
Old May 1, 2007 | 01:10 PM
KCustoms's Avatar
Do you have a MIL light?? If not sometimes it good to do a tune up and check for bad spark wires and make sure you check your cap. Other then that if your running rich a Mil like should appear..
Old May 1, 2007 | 05:05 PM
SHhh__VTEC's Avatar
mil light? What's that? Car has stock exhaust, and stock cat. Car has about 84k kilo's. If the cat is too old, can that make the car run rich? Spark plugs were changed recently. I do need to check the wires and cap though.
Old May 2, 2007 | 04:10 AM
MIL = Malfunction Indicator Light
chrisdean228
May 3, 2017 10:44 AM
bakertime
Aug 9, 2009 01:18 PM
DB1_559
Mar 31, 2007 04:40 PM
Loveless
Apr 2, 2003 03:17 PM
Steppin Razor
Aug 16, 2001 01:52 PM
