16 x7 with 35mm offset on 01 accord
Old Apr 30, 2007 | 05:02 PM
airdad's Avatar
Default 16 x7 with 35mm offset on 01 4 cylinder accord
I have the opportunity to buy these wheels dirt cheap. They have 205 60 16 tires mounted. Will this fit with no rubbing ?
Old Apr 30, 2007 | 05:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 16 x7 with 35mm offset on 01 4 cylinder accord (airdad)
You really have two questions: whether the wheels will fit, and whether the tires will fit.
The wheels depend on a lot of things - bolt pattern, center bore, width, offset, and caliper clearance. Not enough information to answer.
With the tires, tires have a good chance of rubbing any time they are both wider and significantly larger in diameter than the stock size, and these are both. The '01 Accord DX Sedan came with 195/70-14 tires stock. 205/60-16 is almost 4 percent larger, and that's a pretty big difference. I would say there is a good chance that they will rub. (Also be aware that the 4 percent difference also applies to your speedometer/odometer error.) But you should be able to get tires in 205/55-16 which shouldn't rub.
Old May 1, 2007 | 04:20 AM
airdad's Avatar
My LX came with 195 65 15 . I picked up a copy of the 2007 WHEEL AND TIRE GUIDE . It says the 6 cylinder model came with 205 65 15 from the factory. I wasnt sure how big I could actually go. Thanks for your help.
treck_dialect
Nov 6, 2009 03:31 PM
ny153
Jun 8, 2007 06:56 PM
MDP
Jun 1, 2006 04:49 AM
turboman
Apr 23, 2005 04:46 AM
Vampyre
Jul 11, 2004 10:15 PM
