Shaving Bay Question (About Welder)
Old Apr 30, 2007 | 03:08 PM
Civic2bBuilt's Avatar
Default Shaving Bay Question (About Welder)
I am about to shave the bay on my 87 crx but first I would like to know if a 220 welder (I think that is what this is called) will work. I will have to talk to my brotehr in law to get the exact specs but just wanted to see if this will work...
Modified by Civic2bBuilt at 7:41 PM 4/30/2007
Old May 1, 2007 | 06:03 AM
Andy R's Avatar
Default Re: Shaving Bay Question (Civic2bBuilt)
not sure what welder your thinking of, but for welding sheet metal on cars you typically need a wire fed MIG welder with a tank of gas. I use 75% argon 25% co2, which I chose based on the wide thickness of material I use. A good guide to selecting the right shielding gas is this web site:
http://www.weld-direct.com/gas.htm
Now for actual welder selection, if you really only intend on welding sheet metal (or any material 3/16" and thinner) you will be fine with a 115V unit. Some quality units are the Miller or Lincoln 135. I personally weld a lot of stuff near or over 1/4" and have been very happy with my 220V Miller 175. You should be able to rent these units from any local rental store, I imagine around $50 for a weekend rate.
dem0nk1d
Welding / Fabrication
Aug 3, 2008 09:51 AM
Flashmn
Dec 26, 2006 07:29 AM
drift2004
21
Dec 11, 2006 07:36 PM
JDMCRX
Nov 26, 2006 05:43 PM
redsikiller
Apr 29, 2006 12:04 PM
