Oh No, Another Nissan turned Honda Driver!
Old Apr 30, 2007 | 01:53 PM
MovingParts's Avatar
Default Oh No, Another Nissan turned Honda Driver!
Aight aight, I've been driving Nissans for the past five years and got a couple questions about this honda I got at a junkyard. This car is a Canadian, 88' Civic Hatchback, 4spd, D15B1 block, (Head has PM3-7 on it, not sure what the head is from) anyway I drove the car from California to Georgia and this is by far the lightest, most agile car I've driven beside early Z cars, with killer gas mileage too! Anyway my question is how much power is this little car producing? It feels real torquey in all gears some say 70hp but it feels like so much more. This exhaust note is real deep about halfway through the powerband and then a waahhhhh note kicks in and pulls for days. The head looks a lot newer than the block. People tell me it's not vtec which I believe but what is it? Any info would help thanks!
Old Apr 30, 2007 | 01:59 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Oh No, Another Nissan turned Honda Driver! (MovingParts)
That would be a STD hatchback. No VTEC. You are really making only 70HP though, sorry to disappoint: http://www.efsource.net/specs.php
If you want to wake that motor up a bit, the easiest thing to do is a MPFI conversion. If you don't know what that is, use the red "search" button, there's tons of info on the conversion.
Old Apr 30, 2007 | 02:00 PM
aarontrini85's Avatar
its a 70 hp car lol
the head is the same as the d15b7 that base model civics came with it, and it sucks. i dont know what kind of nissan you drove that you think this car is agile lol but with some upgrades you can have fun with it
Old May 1, 2007 | 05:46 AM
Default Re: Oh No, Another Nissan turned Honda Driver! (aarontrini85)
It can't be 70hp no! nooo! jk anyway, how much did the 88-91 Si's put out? A guy at the local shop here said it's a Crx Si or Civic Si head? He mentioned hondas are hard to find stock nowadays because so many parts interchange from other models. Is this bad for the car or good? 1.6L head on 1.5L block? is it logical? like I said it feels torquey. dumbass perhaps?
Old May 1, 2007 | 06:38 AM
iheartmyh0nda's Avatar
your civic is soooo light...so it makes up for the 70hp...hahahahaha... sorta?!?!
Old May 1, 2007 | 07:14 AM
crxnj's Avatar
Default Re: Oh No, Another Nissan turned Honda Driver! (PleaseKeepOffDunes)
88-91 si's only put out about 100hp..and the d15b1/2 head is the same as the si head so it doesnt really matter what that guy says,,the cam is different but its not even noticable withe dpfi...
My advice to you is do mpfi conversion and swap in a 5spd tranny from a dx or si..good luck
Old May 1, 2007 | 08:00 AM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MovingParts &raquo;</TD></TR><TR><TD CLASS="quote">then a waahhhhh note kicks in and pulls for days </TD></TR></TABLE>
haha, that's because it's slow.
The B2/A6 heads are the same casting. The bore is the same between the 2 motors but the stroke changes so they can use the same combustion chamber.
Old May 1, 2007 | 08:31 AM
crazykamper's Avatar
maybe it has a mini me? if the head is newer, are the spark plugs on the front of the head (towards front of car) if its an older head, spark plugs are on back of head....
Old May 1, 2007 | 01:00 PM
Default Re: (crazykamper)
Thanks for being straight up! like i said it's my first honda and what exactly are dual points? two stages in fuel delivery besides multiple or what? could it explain the exhaust note change and power delivery? Canadian cars are the same as U.S. right? why so many questions? but thanks for the help anyway! the plugs are NGK and are toward the back of the engine ! njn63 you're an *** for that but it's all good! I like the 4 spd tranny but is it weaker than the fives? 3rd gear to 100mph is too much fun for now. oh yeah, I come across a lot of H22's for like little to nothing and rated at 180-210hp is it worth tha swap? &lt;----let's try not to use these anymore.
Old May 1, 2007 | 01:06 PM
njn63's Avatar
Default Re: (MovingParts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MovingParts &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for being straight up! like i said it's my first honda and what exactly are dual points? two stages in fuel delivery besides multiple or what? could it explain the exhaust note change and power delivery?</TD></TR></TABLE>
Basically, it's almost the same thing as a carburetor with primarys and secondaries if you know how that works. At least that's how I've heard it explained.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Canadian cars are the same as U.S. right? why so many questions? but thanks for the help anyway! the plugs are NGK and are toward the back of the engine</TD></TR></TABLE>
99% sure the stock head then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">! njn63 you're an *** for that but it's all good!</TD></TR></TABLE>
haha, i was kidding. My car isn't fast either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I like the 4 spd tranny but is it weaker than the fives? 3rd gear to 100mph is too much fun for now. oh yeah, I come across a lot of H22's for like little to nothing and rated at 180-210hp is it worth tha swap? &lt;----let's try not to use these anymore.</TD></TR></TABLE>
http://www.hasport.com has mounts for the H22 into an EF chassis. I can't remember the specific issues with it but i know the passanger side mount has to be moved.
Old May 1, 2007 | 01:41 PM
Default Re: (njn63)
Holy f*****k about $800 for mounts alone huh? Either way is about the same then.
Good B16, B18 and cheap mounts. Or Cheap (but torquey) H22 with expensive mounts with modification to chasis. hmmmm....let's try ebay. what about turbo? (is it even worth it on the D15?)
Old May 1, 2007 | 01:46 PM
njn63's Avatar
Turbo isn't a bad idea, you really need to go MPFI before doing it though as it's a lot safer. Hasport mounts are pricey, i can't remember who else makes them but i know they were more reasonable.
https://honda-tech.com/zero...age=1 -190 pages of SOHC turbo stuff haha
Old May 1, 2007 | 02:08 PM
JJ's civic's Avatar
Default Re: (njn63)
no matter what you do you will mneed to do a mpfi swap. so you prob better off doing that first befor eyou make up your mind on what motor you want.
Old May 1, 2007 | 02:10 PM
try explicitspeed... i know they do all sorts of stuff.. mainly ef/h22....
Old May 2, 2007 | 05:52 AM
I will definitely be multi pointing the fuel system for starters. Later on down the road is the H22 swap I made my mind up. There is a couple modifications that need to be done but it's worth it to me. basically a promised 200 whp stock! I wonder why I rarely see Preludes actually hooked up, I take it that the performance is already there no? Is the prelude chasis that heavy? I do recall riding in my friends si (prelude) and it hit 140+ with no problem. of course he had an intake mani, nitrous, z rated tires, and a couple small mods but the way it delivers the power is too smooth. The vtec seemed more mature. I'll be scoping out a multi, the junkyard should have em no? or is it a part that has issues?
Old May 2, 2007 | 07:36 AM
the jy should have the multi point conv availible.... good luck with it!! you should start a build thread!
Old May 2, 2007 | 07:55 AM
mini-me-power's Avatar
build the bottom end with some pistons and rods, ARP head studs and get peice together a turbo set for bout 1500 bucks and you will have fun.
Old May 2, 2007 | 08:14 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: (mini-me-power)
oh how i miss my std....it did have a little umphhh to it....so i know what you mean...
Old May 2, 2007 | 08:49 AM
Max Kling's Avatar
Dude, search man, there is so much info.
What Nissan did you use to drive for a stock STD to feel "torquey"?
Also DPFI is 2 injectors with 2 runners, and MPFI is 4 injectors (injector per cylinder). DPFI is just 100% for fuel mileage. You need to do a MPFI swap and then a junk yard turbo set up and youll think its the fastest car in the world.
Old May 2, 2007 | 01:12 PM
Default Re: (Max Kling)
As far as nissans I've driven and owned 240Z,(3) 280ZX's,(2) 240SX S13 chasis. one auto one std. I'm a business man, buy em' cheap, clean em', upgrade interior and tires, and sell em' for double. As far as feeling torquey the bottom of the powerband on nissans are way better no doubt. instant torque. But on the honda the top end is far more agressive. You can choose when to really go ya know? hold it at four grand all day long and mash it with no worries. the nissan starts to die after 5 grand. it's a four speed (88 civic) with little to no weight (yeah one of the lightest i've driven) so what little power it is producing feels like plenty. Just floor it in all corners with no issues on oversteer, little understeer though, and have fun! yeah in a straight line to be honest the old inline six's feel hella torquey off the line and jump to 80mph, but as far as how long and how confident I feel doing so just doesn't compare to the feeling of this little bastard.
Old May 2, 2007 | 01:18 PM
Preciate the info on dual and multi points too! I had no idea wtf it was but I see.
it's almost eliminating the carb feel in favor of a more efficient injection system.
that might smooth out my power delivery no?
codysd1
Engine Management and Tuning
23
Aug 7, 2017 07:56 PM
กก4drWHORE!!
30
Jun 10, 2015 10:52 AM
90sedan
Nov 2, 2014 06:38 PM
custom rides401
Oct 26, 2010 11:02 AM
Newkdog
Jan 1, 2006 09:27 PM
