Tips on lining up my jdm front end.
Old Apr 30, 2007 | 07:21 AM
ef9robert's Avatar
Default Tips on lining up my jdm front end.
Guys and gals,
Put my jdm front end on and for the life of me I am unable to line it up properly. I was wondering if any one could give me some tips on this subject.
Thanks.
Old Apr 30, 2007 | 11:47 AM
ef9robert's Avatar
no tips? tried to line it up by myself couldnt get it right, should i have another body help me out?
Old Apr 30, 2007 | 02:55 PM
harmonator84's Avatar
Default Re: (ef9robert)
Ok, I have never installed a JDM front...but I have replaced front ends on many different vehicles. The easiest way I found is to install everything loosly. Meaning put all the bolts in but dont tighten them down. Get everything aligned the way you want them then tighten the bolts down 1 at a time.
Good luck.
Old Apr 30, 2007 | 03:00 PM
Crx Jimmy's Avatar
Default Re: (harmonator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I have never installed a JDM front...but I have replaced front ends on many different vehicles. The easiest way I found is to install everything loosly. Meaning put all the bolts in but dont tighten them down. Get everything aligned the way you want them then tighten the bolts down 1 at a time.
Good luck.</TD></TR></TABLE>
yes I second that^^. My crx sir front end went on fine, the bumper lines up just like stock. the headlights I had to shim down a little by putting washers between the headlight and support. If it doesnt line up and there are large gaps your car might have been in an accident and something is bent.
Old Apr 30, 2007 | 07:26 PM
ef9robert's Avatar
i think that is the case, took off the bumper today and looks to be damage on the passenger side, i think i can line it up right if i get a longer bolt.
Tricid
Apr 26, 2007 08:43 AM
InTeGrA GsR 321
May 31, 2005 05:31 PM
djay86
Aug 31, 2002 10:46 AM
