Clutch pedal suddenly came up.Anybody have any explanations???
i was wiring my v tec yesterday and i went to drive my rex.all of a sudden i turned it of and i was chilling out for a while.When i went back into the car to drive it I noticed the clutch pedal was pretty high and felt a bit stiffer too.Any body have any explanations.Its a cable b16 trany.pretty strange if you ask me.
look down by your tranny at the front and you will see a lever coming from your tranny. then on that lever there will be a cable with a black plastic type nut on top of the lever. make sure that your threads on that bolt didn't strip out. if not then try to loosen it and see if there is a difference.
hope that helps
GL!!
i've got tranny problems too. lol
hope that helps
GL!!
jwbnavy
12
Dec 2, 2007 06:36 PM
