Progress 22mm rear sway bar + tie bar??
Thinking about ordering the progress 22mm rear sway + tie bar off of crsx. Just curious if anybody had any feedback to offer about this product and i was also wondering how difficult the install would be. Thanks!
install is not that hard, but not tremendously easy. progress has good parts, i personally like my 25mm adjustable Comptech. you'll be expecting a noticable difference when you take turns.
im probably going to have to jack the whole *** end of the car up and take both rear tires off right? Ive actually never even seen how the sway bar is attached to the car. Yeah im hoping it makes a bit of a difference. There's a lot of roll in the car now as it sits going around corners im hoping this will tighten it up a little.
dont need to take off the wheels. but yes you'll have to jack up the whole *** of the car. remember to use jackstands to hold up your car not just the floorjack. removing the wheels helps if you've got bigger hands (my hands are kinda small so i can fit them into smaller spaces)
oh yeah
its a big difference on terms of handling
i have the 24mm and i love it
only problem i have with it is that it doesn't fit properly with my stock exhaust
seems to rub the bar on every little bump
tweek_boii
19
Nov 13, 2009 06:31 AM
chrisw85
Suspension & Brakes
Oct 24, 2006 01:02 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
