z6 build/mini-me what is better?
Old Apr 29, 2007 | 04:13 PM
projectef's Avatar
Default z6 build/mini-me what is better?
i already have a built z6, all motor. and i was wondering what set up would have a higher comp.. in the end. should i do a built mini-me w/the a6 block or i should jus leave it straight z6. what if i put the built z6 head on the stock a6 block, what would the comp... be? which crank is better the z6 or a6?
z6 block has a 11:4:1 comp... w/the stock oem head gasket (blue printed)
10:5:1 comp... srp/je pistons
eagel h-beam rods w/balanced crank (stock z6)
z6 head full crower w/stage 2 (blue printed)
Old Apr 29, 2007 | 04:27 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: z6 build/mini-me what is better? (projectef)
If you already have a z6 built why swap?
using zeal speeds calc is good for a range of what your comp will be like, it tends to read a tad high though.
Frankly keep what you have.
Old Apr 29, 2007 | 04:36 PM
projectef's Avatar
beacause i want a lil more higher comp...
Old Apr 29, 2007 | 06:27 PM
Ass$nyper's Avatar
Default Re: (projectef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">beacause i want a lil more higher comp...</TD></TR></TABLE>
Are you sure you do or do you think you do?
Higher comp on pump gas you'll have to pull some timing, you might lose power even.
What's your whole setup, and what fuel will you be using?
Not to be a dick, but alot of people jump to the idea more comp &gt; less comp. It's just not always true. Wouldn't want to see you go down the wrong road.
Old Apr 29, 2007 | 06:50 PM
SIred91's Avatar
Rainman
Default Re: (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">
X2, nice one maxi.
Old Apr 29, 2007 | 08:16 PM
projectef's Avatar
z6 head: obd1 untuned
crower springs/retainers
supertech valves
crower stage 2
skunk2 im
72mmtb
ls injectors
aem fuel rail
skunk2 cam gear
full msd
z6 block:
stock balaned crank
h-beam rods
spr 10:5:1 comp...
golden eagle block guard
acl bearings
ext:
stage 2 clutch
stock flywheel
stock cranks pulley
aem pulley kit
cityofcaterpillars
Dec 18, 2017 06:14 AM
dseriesboulder
15
Jul 2, 2013 01:54 PM
nonuthinnewb
Aug 30, 2006 12:44 PM
dohdoh420
13
Oct 27, 2005 12:33 PM
gtcali
Oct 31, 2002 08:31 AM
