rom burning help
Old Apr 29, 2007 | 03:20 PM
zenon8890's Avatar
Default rom burning help
plz help me on this one guys.
https://honda-tech.com/zerothread?id=1968415
Old Apr 30, 2007 | 03:24 AM
zenon8890's Avatar
Default Re: rom burning help (zenon8890)
bump
Old Apr 30, 2007 | 07:16 AM
sanimalp's Avatar
$cat /dev/urandom
how did you erase it? do you have a UV eraser? it has been my experience that uv eraseable chips are kinda flakey.. they work, but not consistenetly .. It is best if you buy a uv eraser from ebay or somewhere.. or just buy a electronically eraseable chip.. they are only like 5 or 6 dollars.
you should burn a stock rom on the chip and make sure your car runs ok, and then go back to the basemap. the basemap may be the issue. I tried a basemap to get my car to run a while ago, and i was better off using the stock map and adjusting from there. you can always copy the stock maps into one of the NGseries roms from PGMFI so you can have launch control and all that too.
if you are running non stock injectors or fuel pressure, my suggestion may not work for you. good luck.
Old Apr 30, 2007 | 12:51 PM
zenon8890's Avatar
Default Re: rom burning help (sanimalp)
i have a 450cc basemap on pr3, the problem is i lost my injectors in the mail and i'm still runnning stock, and it bogs when i use the 450cc map, i cant find any pr3 running a sohc vtec basemap, thats why i made my own by changing the 450cc map injector size to 240, thats exactly what i did and i guess it should work
ge_itr
Dec 28, 2009 03:47 PM
bewstn ex
Mar 16, 2008 07:01 PM
93c1sol
Jun 30, 2006 10:47 AM
tslex
Jun 5, 2004 11:51 AM
