Good Suspension Upgrade
I just want to make the car handle better. What would be the best bang for my buck to make the car handle better? And actually notice it handle better?
I would just add drop springs. Neuspeed would be my choise. I have a 2000 accord coup that I bought new and put the Neuspeed sport springs on shortley after I got the car. The springs come with a 2 inch drop but if you want something more drop go with the race. But wth the race you will needed a camber kit. Ant thing below a 2 inch you will need a cambe kit to keep you ride alined. Haven't replaced the shocks yet. I thank it rides better than factory. But if you are needing shocks I would reckomend the Konie yellows, there are a little pricey but well worth the money. Had them on my old car. Good luck with up surch
i have kyb agx, neuspeed race springs and a front strut bar.
i had a shop do an alignment afterwards and i have had NO CAMBER issues and i have 2.25" in the front and 2" in the rear..
handles great, compared to stock.. sway bars and master bushing kit next after my clutch and flywheel..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy »</TD></TR><TR><TD CLASS="quote">i have kyb agx, neuspeed race springs and a front strut bar.
damn how did you get away with that. i had H&R sport springs put in my front and my fronts camber 2 degrees on one side and 2.8 on the other.
</TD></TR></TABLE>damn how did you get away with that. i had H&R sport springs put in my front and my fronts camber 2 degrees on one side and 2.8 on the other.
I have Tenzo springs
and KYB AGX's and a front strut bar..much better handling than stock but I dont recommend the springs I dont much like them..im looking at getting some ground control coilovers to go with the AGX's and also a rear strut bar and a rear lower tie bar is a nice upgrade...also Ive heard great things about the sway bars suspension techniques makes..you can get them from http://www.tasauto.com
