B18B Block..What's all needed to build..?
Old Apr 29, 2007 | 12:19 PM
MATiC's Avatar
Default B18B Block..What's all needed to build..?
so i recently picked up a bare b18b block..
i already have a good running b18 in my car but i thought it would be a fun project to build a motor of my own..
i, myself, am a complete newbie when it comes to internals and builds but i have alot of friends who are gonna help me out..
first off, i need a shopping list..
i know for a fact that i'm going to be building it NA non-vtec.. i dont need ridiculous power, just want a strong reliable motor..
keep in mind, i only have the bare block..
include anything and everything needed..
(crank, rods, pistons, etc etc)
Old Apr 29, 2007 | 12:47 PM
lsvtec_cp's Avatar
New User
Default Re: B18B Block..What's all needed to build..? (MATiC)
B18B block? You could do a lot with that. I got the same block and I chose to go LS VTEC with a 93 GSR head. With the right combo of block internals, I made my **** quick. If I were you I would pick up a VTEC head. You would get the response you want out of a motor and you don't have to worry about it breaking on you unless you're mobbing every day all day(that's how I blew my last B18B block). In mine, I went with B16 12.8:1 pistons with Eagle rods and crankshaft. You can buy a stroker kit from http://www.briancrower.com for a B18B, just be sure to go with the high compression set up unless you're planning on boosting it. Hope this helps ya out.
Old Apr 29, 2007 | 01:14 PM
doood's Avatar
been there done that
Default Re: B18B Block..What's all needed to build..? (lsvtec_cp)
ls crank
ls rods
p30 pistons
oem bearings, seals, gaskets, etc.
keep it simple
Old Apr 29, 2007 | 04:15 PM
integ401's Avatar
First give us a figure of what your power goals are going to be. Remember, parts aren't going to be cheap and neither are the tools. Good luck
Old Jun 30, 2007 | 07:02 PM
Jabinya's Avatar
Default Re: (integ401)
What kind of compression would you see with a B18B block with LS rods and P30 pistons and a stock B18B head? What would you need to tune this and have it reliable enough to be a daily driver?
Modified by Jabinya at 8:24 AM 7/1/2007
93coupe1330
Jan 11, 2009 09:13 AM
lyles167
Jun 3, 2005 08:58 PM
Crab-Cakes
Dec 12, 2003 11:38 PM
