New Swapped B16 won't start HELP!!!
I just finished the install on my B16 OBD-1 into my 95 EG. When I went to start the car for the first time it didn't fire at all. Now I've gotten it to the point where two cylinders seem to be firing. I pulled the plugs and it looks as though #2 and #4 cylinders are firing but not the others. I tested the spark and thats good on all cylinders. I'm thinking it's the injectors, but I'm not sure. Any input is greatly appreciated. I've got the injecotrs soaking in fuel now to see if that helps. Also, will the stock d15 non-vtec injectors work to test if its the injectors or not???
I know more then that.... but thanks for the help. I got it to run by switching the injectors. I just need to find out how to clean the stock injectors that came with the motor.
Kusai.Nihonjin.Desu
21
Apr 16, 2005 08:08 PM
TurboedGSR
May 6, 2004 01:29 PM
