having trouble starting it up??
Old Apr 29, 2007 | 06:42 AM
classciv's Avatar
Default having trouble starting it up??
i have an 88 crx si that i am swaping a 91 crx si engine&tranny into. i swaped the 88 intake onto the 91 motor, got all the wiring hooked up and thought i would see if all the electronics where working so i went in and turned the key, and the engine turned over but would not start, it would rev up and sound like it was going to go if i held the key in for aoubt 15 seconds but then it would shut down and start all over again. i noticed that there was some fuel leaking out of the line off the fire wall,and the only lines i was not sure about when i was hooking it back up where the small lines off the intake that go to the map sensor(i think). i am going to go back out and hook up shift linkage and try and re-tighten the fuel lines but is there anything i have over looked? what else could my problem be?
Old Apr 29, 2007 | 08:32 AM
classciv's Avatar
Default Re: having trouble starting it up?? (classciv)
anyone have any idea?
mwagner
Nov 7, 2010 11:35 PM
nocsyn
Aug 25, 2008 10:45 PM
classciv
11
May 9, 2007 03:51 PM
Twilightepitaph
Dec 21, 2006 11:04 AM
