Dust cover for clutch/flywheel? 6th gen.
Old Apr 29, 2007 | 06:24 AM
98savage's Avatar
Default Dust cover for clutch/flywheel? 6th gen.
Alright, so I got my manual conversion done....it's over at Honda getting the keys reprogrammed so I can drive that biotch. Now, I'm missing the dust cover that goes over the clutch and flywheel....and I can't find that part listed on Majestic or SLH....so does anyone know the part number or where to get it?
Old Apr 29, 2007 | 08:27 PM
98savage's Avatar
Default Re: Dust cover for clutch/flywheel? 6th gen. (98savage)
Someone has to know.
I guess I can just go to Honda and get the part number. Only thing is, it probably isn't on Majestic - seeing as I can't find it under any transmission or body parts. Then again, a part number goes a long way.
Old Apr 30, 2007 | 04:17 AM
BlkChryKord's Avatar
I've never heard of a dust cover going over the clutch/flywheel. I can't even see why one is needed since it's all contained within the transmission.
Do you mean a scatter shield?
Old Apr 30, 2007 | 05:04 AM
stinker504's Avatar
I think he's talking about the lower cover that is held on by 3 bolts and gives you access to the flywheel.
When I did my manual swap I couldn't find that part number either. My H23 trans that I used came with one but I had to grind away at several points to make it fit.
If you happen to find the part number please post it.
Good luck.
Old Apr 30, 2007 | 05:45 AM
I tried searching majestic but their links are all f'd up right now.
Old Apr 30, 2007 | 07:49 AM
98savage's Avatar
Default Re: (BlkChryKord)
Stinker got it....it's a cover that goes on the bottom and gives you access to the flywheel. I can't find that part at all so I guess I'm just going to have to ask the Honda dealership. I'm heading up there right now anyways. But if I can't find it then I don't know. I don't want anything getting inside and messing up the flywheel.
croat
Aug 5, 2014 07:45 AM
t0kyoStatus
13
Jan 12, 2009 07:40 PM
CALC!_JUST_du_IT!
Dec 7, 2007 09:22 PM
lildrgn2.0
Jun 22, 2004 06:56 AM
