Can this be fixed? front lip..
This happened to me last night as I was coming out my driveway
Basically the lip broke off the bracket and my friend said once it breaks its a wrap but I would like to think otherwise with your expertice guys thanks
if the lip is plastic, scuff down the edge of the broken parts to remove the paint, line it back together, find a clamp or something to hold it in place and run a soldering iron down the crack to melt (vulcanize) it back together.
once this is done, take the lip off and run the soldering iron on the backside of the crack. you can use plastic bumper repair epoxy to reinforce it from the inside and also to fix the cosmetic imperfections from the soldering iron.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-ish »</TD></TR><TR><TD CLASS="quote">gorilla glue that bitch
Good ****, i used that alot in my carpentry days
Or get 2 part epoxy
</TD></TR></TABLE>Good ****, i used that alot in my carpentry days
Or get 2 part epoxy
