maby a bad question or 2. but please help
Old Apr 28, 2007 | 08:01 PM
twistedimage's Avatar
Default maby a bad question or 2. but please help
will civic ex or si mpfi harness fit in a lx sedan? will it plug and play? i think i have rad some where that the plugs are diff from si/ex mpfi to dpfi cars
also will the stock trans bolt on to the z/c motor? any mods needed? i want to do a zc swap in my lx dpfi sedan. help me
i have been searching and have not got a solid answer
Old Apr 28, 2007 | 08:50 PM
Loaded Butane's Avatar
Default Re: maby a bad question or 2. but please help (twistedimage)
Youll want to use your stock harness and wire the mpfi wires into it or buy a rywire harness.
The stock trans will bolt up.
Old Apr 29, 2007 | 08:09 AM
does it matter that it is the 88 integra motor vs the zc?
and i should use the 88 teg ecu correct!
Old Apr 29, 2007 | 09:28 AM
the king.'s Avatar
Default Re: (twistedimage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedimage &raquo;</TD></TR><TR><TD CLASS="quote">does it matter that it is the 88 integra motor vs the zc?
and i should use the 88 teg ecu correct!</TD></TR></TABLE>
im not 100% on the ecu but i know the 88 integra motor wont bolt into a 88-91 civic, also it has like -20 hp.
Old Apr 29, 2007 | 05:55 PM
Default Re: (the king.)
You can use the 88 Teg ECU. I woudlnt do the 88-89 Teg swap cause its a pain in the *** and not worth it.
Old Apr 30, 2007 | 06:19 AM
thanks guys
Wes90civic
11
Jan 6, 2004 11:49 AM
JLockheed
Dec 16, 2003 02:50 AM
adnoh90Civic16
Sep 20, 2003 05:53 AM
It's*BOLO!!
Jan 5, 2003 11:23 AM
kamikaze9i6
14
Jan 4, 2003 01:29 PM
