O2 Sensor 99-00 Si behind Cat Need Help
Hi i have swap a B16a2 99 Civic Si engine into my 99 EK and i need help wiring the second O2 sensor to my Ecu i wonderd if anyone has done this Swap and could help me fix this. it is the second O2 sensor behind the Cat and it needs to be wired up cause the Si has a body plug and my Ek dont
The only O2 sensor you would have to wire would be if you had a DX, LX where the seconday O2 sensor is located under the hood and you were using a 99-00 Si/EX harness. STOP saying EK
find your pinouts and use the plugs and wires from your DX harness to wire it up
http://technet.ff-squad.com/
