ZC Swap problem >=0[
Old Apr 28, 2007 | 03:48 PM
llred_devil2001ll's Avatar
Default ZC Swap problem >=0[
Well everything can hook right up but I noticed that the plugs on the driver side don't match...I hear I gotta change axles as well...I need help completing this projekt this weekend...do I need wiring? axles? anything else? I can post pictures for detail...I'll be logged on for a good while...
Well I guess my hatch is a 91 Civic Hb DX...droped in a ZC SOHC...
<center>
</center>
Old Apr 28, 2007 | 04:09 PM
89crxsiVT's Avatar
Default Re: ZC Swap problem >=0[ (llred_devil2001ll)
ya there is some wireing you need to do go to http://www.phatwhippincrx.20m.com/photo6.html They tell you what you need for the wireing. I found it because i am looking to do the same swap to my 89 crx si but can't find a good used motor. We'll good luck i donlt know about the axles.
Old Apr 28, 2007 | 04:12 PM
Slomo_civic's Avatar
pretty sure if you are using your dx transmission, the stock axles will work.
if using the zc transmission i think that you need integra axles with the zc intermediate shaft.
Old Apr 28, 2007 | 04:15 PM
Default Re: (Slomo_civic)
Nah...cause I had a 4 speed transmission...but I'm no tsure if the transmission I put in is a ZC or an SI...what is the fastest and easiest way to find out what I got?
Alright what I see I gotta repin the dizzy plug and use my old dizzy plug on my stock motor harness....know I need help knowing where to relocate every plug on the old plug....
Modified by llred_devil2001ll at 6:34 PM 4/28/2007
88EF4dr
Jul 12, 2011 06:42 AM
31flavorscivic
Feb 14, 2005 01:08 PM
crxzcracer
Mar 11, 2004 10:51 AM
hondaqwert
Mar 3, 2004 06:00 AM
