Mechanic needed for fixing up the Air Conditioning of my 93 Civic
If somebody is interested in earning some side cash and it is capable of doing A/C works, please help me out.
Problems:
R-12 system
AC failed to work at all around 100 degree and it would work and then fail and then work again intermittently about 10 minutes each around when the temperature is below 100 degree (not extremely hot). When it works, the AC blows icey cold air and the idle of my engine is normal (I can feel the drag of my engine power). When it doesn't work, my idle stays at 1500 rpm and the AC blows room temperature air. Doesn't feel the drag either (compressor clutch slipped/ failed to engage?).
Please contact me by PM or by phone if you are interested. Located in West Covina, CA 91791
Thanks
Cliff
(626)200-8765.
Problems:
R-12 system
Thanks
Cliff
(626)200-8765.
its going to be hard to work on a r-12 system because its almost impossible to get r-12 anymore. if it was a r-134 system i could help you, but i cant gaurantee anything on a r-12 system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex »</TD></TR><TR><TD CLASS="quote">its going to be hard to work on a r-12 system because its almost impossible to get r-12 anymore. if it was a r-134 system i could help you, but i cant gaurantee anything on a r-12 system</TD></TR></TABLE>
I am absolutely open to converting to R-134a. I think it might turn out cheaper overall. Can you do the conversion too?
ill see what i can do. if your system is still charged it might be just getting the conversion refrigerant/r-134 with the correct oil and ac fittings. ill get back to you monday night if i have internet with a price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongph »</TD></TR><TR><TD CLASS="quote">
I am absolutely open to converting to R-134a. I think it might turn out cheaper overall. Can you do the conversion too?</TD></TR></TABLE>
to convert ur r-12 to r-134 all u need to do is go buy the fittings for the r-12 to r-134 at the store like pep boys, and stuff..... and recover, evacuate all th r12... i work for honda...... i might be able to help i work in culver city
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboed00EM1 »</TD></TR><TR><TD CLASS="quote">
to convert ur r-12 to r-134 all u need to do is go buy the fittings for the r-12 to r-134 at the store like pep boys, and stuff..... and recover, evacuate all th r12... i work for honda...... i might be able to help i work in culver city</TD></TR></TABLE>
and the correct oil. but yes thats basically all there is. if he cant help you than i might be able to
If the problem is happening when it is very hot the system may be going off on a high pressure switch.
You should check your A/C condensor (Next to the radiator) for debris or damage, you might also want to spray it out with a waterhose and see if its dirty.
Magpulman
Jul 9, 2012 07:35 PM
neEven
Jul 23, 2005 12:49 PM
