what are symptoms of a bad temp sending unit
Old Apr 28, 2007 | 01:37 PM
Boost Junkie 83's Avatar
Default what are symptoms of a bad temp sending unit
I just completed a b16 a swap into a 91 hatchback.. I bought the car for the swap and the heat gauge didn't work in it, but after I finished the swap it still didnt' work.. I've tested continuity on the signal wire from the sender to the gauge cluster, and the needle bounces when I turn on the ignition. I've also tried 3 different gauge clusters (fried one in the process. don't go poking around with a ground wire.) I also tried hooking the heat gauge directly to the signal wire and power/ground.. I'm at my wits end.. the heat gauge worked in the the last car I had this motor in..
So what are the symptoms of a bad temp sending unit? Anyone have any idea's of what I might be missing?
Also if it makes a difference, I haven't heard the fan kick on once in all the times I've ran the car so far
Old Apr 28, 2007 | 05:08 PM
Default Re: what are symptoms of a bad temp sending unit (Boost Junkie 83)
n/m I figured it out
Old Apr 28, 2007 | 05:41 PM
Crx Jimmy's Avatar
what was it?
dejay2014
May 16, 2014 02:36 PM
bighoss77
Jul 21, 2012 03:55 AM
rob1235
May 18, 2011 04:17 PM
civic46
Dec 31, 2007 05:15 AM
crucial-vtec
Oct 28, 2005 11:42 AM
