CODE 14 on B18A swapped CRX?
Old May 29, 2002 | 06:49 PM
Toxic's Avatar
Default CODE 14 on B18A swapped CRX?
I have a 88 CRX Si w/ a B18A out of a 92 LS, My CEL is on and throwing a Code 14, What is it? Could someone please point me in the direction of list of codes? Thanks.
Jon
Jon58701@Email.com
[Modified by Toxic, 3:49 AM 5/30/2002]
Old May 29, 2002 | 07:54 PM
RexB16's Avatar
Default Re: CODE 14 on B18A swapped CRX? (Toxic)
code 14 is idle air control valve. take it off and clean it out. (that little screen) if u still get the code try a new iacv, i have a few if you need.
Old May 29, 2002 | 08:21 PM
Jared's Avatar
Default Re: CODE 14 on B18A swapped CRX? (RexB16)
Or you have it plugged into something else.
Old May 30, 2002 | 12:19 PM
Perfectionist's Avatar
Default Re: CODE 14 on B18A swapped CRX? (Jared)
Could be right... The plugs for the FIV and IACV are similar.
Old May 30, 2002 | 12:23 PM
FUP23's Avatar
New User
Default Re: CODE 14 on B18A swapped CRX? (Perfectionist)
The plug on the intake manafold should be green/red wire. Make sure its right.
Old May 31, 2002 | 12:48 PM
CimorelliCRX's Avatar
Default Re: CODE 14 on B18A swapped CRX? (Devin17)
What do you use to clen the IACV? Carb cleaner? That works dont it, or water? Mine is filthy and I am hrowig a code 14, so... Just wondering..
Old May 31, 2002 | 04:17 PM
fixhondas's Avatar
Default Re: CODE 14 on B18A swapped CRX? (CimorelliCRX)
A code 14 indicates a problem with the IACV circuit- the ECU looks for a specified resistance -cleaning it out won't fix the code. Check the resistance at the IACV. You should get between 8 and 15 ohms. Also verify there is not continuity between either terminal and body ground. With the key on there should be battery voltage between the BLK/YEL wire and ground.
KDvtec5757
Aug 17, 2008 05:18 PM
racingcrx
Apr 10, 2007 03:30 PM
civic4dr2000
Apr 2, 2006 04:41 PM
Bnjmn
Jan 3, 2004 04:50 PM
l
Mar 24, 2002 07:47 PM
