88-91 D16A1 Ls and D16A6 Crx Si questions???
Old Apr 28, 2007 | 12:44 PM
hondacrxturboSi's Avatar
Default 88-91 D16A1 Ls and D16A6 Crx Si questions???
Are the throttle bodys the same size or is Ls bigger?
Ecu out of the ls can be used in the crx si just plug right in?
i know Ls rev higher..
The injectors are they the same size or is Ls bigger?
Can i use the D16A1 ecu with a sohc zc?
Old Apr 28, 2007 | 02:53 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 88-91 D16A1 Ls and D16A6 Crx Si questions??? (hondacrxturboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxturboSi &raquo;</TD></TR><TR><TD CLASS="quote">Are the throttle bodys the same size or is Ls bigger?
Not sure on the throttle bodies. The ECU will work with a D16A6 or ZC motor and will bump your redline up a little bit. Pretty sure that the injectors are the same as well.
prcrx124
Apr 27, 2004 10:44 PM
4door93civic
Oct 22, 2003 09:15 AM
EGHatchy
Jul 15, 2002 05:38 PM
dustin
21
Oct 10, 2001 09:44 PM
