Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
install advice
Old Apr 28, 2007 | 11:51 AM
Default install advice
before i buy jdm H emblems, are there any screws that hold the stock ones in place, or is it double sided tape?? Also, should i trust the honda dealership to install my stechs or can i do it myself? Pretty mechanically inclined. Thanks in advance!
Old Apr 28, 2007 | 12:05 PM
Honder07si's Avatar
You can definatly do it yourself, but..... the rear stock emblem has plugs that are about an inch apart and is a peice of cake to get off, and the jdm emblems' plugs are wider and will not fit you will need to snip those off to get it to fit on right, ot does have very sticky tape that you use to put it on......
The front emblem is a little but more of a pain in the ***, it is held on by two screws that you can access from behind, the plugs that the front jdm emblem come with will fit right into the spots where the stock emblems screws were, and it also has double sided tape that you use.
A hairdryer or heat gun will be a nice addition to the job if you have one to loosen up the stock sticky tape stuff, just heat it up for about 30 sec and use fishing line or a old plastic card to "jimmy" it off
The whole job should not take more than 15-20 min
Hope this helps
civicfg1's Avatar
Default Re: install advice (gangstar1219)
it is double sided tape... is to easy to install u can do it by ur self...but the front emblem u need to take out ur grill cause the stock emblem have srew... n the jdm red h emblem is double sided tape same as the rear...
Old Apr 28, 2007 | 12:09 PM
Default Re: (Honder07si)
so, just pop off the rear then, no screws? im assuming thats what you meant, i really appreciate your otherwise detailed description of the whole process!!!!
Old Apr 28, 2007 | 12:14 PM
Honder07si's Avatar
the rear does not have screws, there more like plugs, you dont need any "tools" to get the rear off
Old Apr 28, 2007 | 01:10 PM
NoPainNoGain's Avatar
https://honda-tech.com/zerothread/1935166
avargas28
Jun 24, 2009 07:26 AM
ekturbosi88
Honda Fit
11
Jan 23, 2008 07:41 AM
sCeRaXn
Nov 3, 2003 10:27 AM
Screamer
Mar 25, 2003 12:51 PM
armharm
Oct 31, 2002 11:51 AM
