no power!!??
ok i just did a timing belt,water pump, and headgaskit job on my 92 si..Ok when i start it it runs fine but when i give it gas it wants to die it boga really bad..and if i try and drive it.ha ..no power at all!!!..i played with the Throttle cable and it stays the same..anyone know whats up?
i would dbl check the timing belt sounds like you set the cam timing for a 1.5 and not a 1.6 that will cause no power and bogging and yes it will make the engine run run since it is working harder to compensate for the retarded timing of about 23 degs.
good luck
good luck
sandiegosmoka
Jun 11, 2009 05:12 PM
92gs...92dx
12
Aug 15, 2007 09:31 AM
