Sprayed engine -WON"T START
Call me a dummy but I had planned on doing a little cosmetic work on my 1996 Accord so I thought I would start with the engine. I have cleaned many before with out any problems. I started it up and sprayed it down while it was running as I always have. Let it run for 10 - 15 min. after I was finished and now it won't start. I checked for moisture in the distributor cap and it was fine, wires looked OK too. It turns over fine any all electricals work ...it just won't start. Any ideas?
I figured it out!
When I made sure that there was no moisture in the distributor cap, I had to remove an plug to get at one of the bolts to for the cap. It seems that I forgot to plug it back in. You learn by admitting your mistakes (no matter how stupid they are!).
fortyfacemohwhat
Oct 17, 2008 05:40 PM
