95 accord idles up and down
Old Apr 28, 2007 | 07:36 AM
dawnm6's Avatar
Default 95 accord idles up and down
I have a 95 accord that idles up and down. The check engine light comes on sometimes also it doesn't stay on all the time. What do you think the problem could be and how much do you think it will cost to fix it.
Old Apr 29, 2007 | 10:29 AM
flatline911's Avatar
Default Re: 95 accord idles up and down (dawnm6)
Throttle Position Sensor. You can test this by un hooking it and see if it stops. Honda will not just sell this part the sell the complete TB and it is not cheap. Best thing is to find a used one.
Old Apr 29, 2007 | 12:09 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: 95 accord idles up and down (flatline911)
Mine is doing the same and I couldn't find a vacuum leak.... gonna check this as well. Thanks
Old Apr 29, 2007 | 01:22 PM
ricebike's Avatar
Default Re: 95 accord idles up and down (213374U)
one of the 1st steps you should do is to see if there are any trouble codes from the car's pc...
there are good resources on this forum for that... or you can access this: http://www.troublecodes.net/honda/
GL!
Old Apr 29, 2007 | 04:29 PM
gulfview's Avatar
Default Re: 95 accord idles up and down (ricebike)
Do a search on IDLE or UP AND DOWN IDLE. You will have many responses, including from myself.
There can be MANY resaons for it.
Old Apr 29, 2007 | 05:13 PM
hb_guy's Avatar
clean your fitv and iacv... i just had an idle issue last week and i cleaned them with brake cleaner and it fixed my issue. took like 1/2 hour.. i also bled my cooling system cuz if you have air in your cooling system it can also cause an idle issue..
good luck
Old Apr 29, 2007 | 05:28 PM
JohnD1079's Avatar
if what they said dosent work, then you could try seafoam
raffydogg
Apr 19, 2008 01:17 PM
elijah
May 29, 2006 08:44 PM
OzzieAccord
May 22, 2006 10:13 PM
spddmn124
May 24, 2005 05:10 PM
