Differences between the Coupe and the Sedan other than the obvious
Old Apr 28, 2007 | 03:34 AM
jwrape's Avatar
Default Differences between the Coupe and the Sedan other than the obvious
I understand that Accords Sedan and Coupe are different because of the doors, BUT since the EX Coupe has a different rear end and slightly cosmetically different otherwise, is the Coupe and Sedan pretty much the same mechanically. Are the parts interchangeable or do I need to search for only EX Coupe parts when looking for stuff to upgrade with?
Hopefully, this is not too stupid of a ?.
Old Apr 28, 2007 | 03:41 AM
YeuEmMaiMai's Avatar
Default Re: Differences between the Coupe and the Sedan other than the obvious (jwrape)
cars are mechanically identical no exterior body panel are interchangeable however you can do a front end conversion on either car to the sedan or coupe
Old Apr 28, 2007 | 06:26 AM
JimBlake's Avatar
Mechanical bits should be the same, but I can think of a few exceptions. Stuff like this...
Exhaust sections are different length.
Cable for releasing the trunk is probably different length.
Steel brake & fuel lines under the car are different length.
Steering knuckles might be different because wheelbase is different?
Old Apr 28, 2007 | 07:49 AM
jwrape's Avatar
Cool, thanks for the info.
Old Apr 28, 2007 | 07:07 PM
Tx_Accord98's Avatar
if you are talking about a 6th gen coupe and sedan, all of the basics are interchangable.
Bora-Frankfurt
Jul 12, 2017 11:52 PM
xsirenax
Apr 9, 2011 06:04 PM
Frostwhite_DB8
Jun 17, 2007 08:30 PM
Crab-Cakes
Nov 15, 2004 01:32 PM
