accord 98-00 drum to disk break conversion!
Old Apr 27, 2007 | 09:27 PM
GreedyAzn's Avatar
Default accord 98-00 drum to disk break conversion!
I i was wondering if anyone has done the drum to disk break conversion on the 98-00 accord before or any topic in honda-tech have this type of conversion?
if so please provide me with some information
thank you
Old Apr 27, 2007 | 09:32 PM
aznpridelivin2o3_cg5's Avatar
Default Re: accord 98-00 drum to disk break conversion! (GreedyAzn)
uh, i have a 98 EX with discs. so i duno ?
Old Apr 27, 2007 | 09:33 PM
lowered94accord's Avatar
http://www.cb7tuner.com/vbb/showthread.php?t=10495
I know its not your year accord but it should be about the same..or atleast youll get the point on what you need to do I guess.
Old Apr 27, 2007 | 09:47 PM
Crono139's Avatar
BlkChryKord has done it, but with an upgrade to V6 brakes.
Old Apr 28, 2007 | 10:14 AM
BlkChryKord's Avatar
Default Re: accord 98-00 drum to disk break conversion! (Crono139)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">BlkChryKord has done it, but with an upgrade to V6 brakes.</TD></TR></TABLE>
I haven't done it yet. It's "under construction"
Old Apr 29, 2007 | 02:01 AM
Lucid317's Avatar
Default Re: accord 98-00 drum to disk break conversion! (BlkChryKord)
what all do you need from the v6???
Old Apr 29, 2007 | 02:15 AM
Default Re: accord 98-00 drum to disk break conversion! (Lucid317)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucid317 &raquo;</TD></TR><TR><TD CLASS="quote">what all do you need from the v6???</TD></TR></TABLE>
Well that all depends on whether you're just going to do a rear disc conversion from an EX 4cyl or go for the full 5-lug/rear disc from a v6 like me.
Old Apr 29, 2007 | 11:07 PM
Lucid317's Avatar
i know you would have too do the full conversion if u use the v6. It would be very hard odd if your front were 4 and rear were 5. So what all parts would you need if using the v6.
Old Apr 29, 2007 | 11:15 PM
Rainy City's Avatar
Think about the whole brake system on your car. Now think of it on the v6. You'll have to take it off the other car, and put it on yours. Now I don't know how much you're pushing your Accord but I don't think you need it.
Old Apr 30, 2007 | 04:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucid317 &raquo;</TD></TR><TR><TD CLASS="quote">i know you would have too do the full conversion if u use the v6. It would be very hard odd if your front were 4 and rear were 5. So what all parts would you need if using the v6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainy City &raquo;</TD></TR><TR><TD CLASS="quote">Think about the whole brake system on your car. Now think of it on the v6. You'll have to take it off the other car, and put it on yours. Now I don't know how much you're pushing your Accord but I don't think you need it.</TD></TR></TABLE>
There's your answer, it really couldn't be any more obvious
Old Apr 30, 2007 | 08:22 AM
Cronousman's Avatar
you would need the entire knuckle assembly from the EX 4 cyl...i wouldnt go with v6 brakes only on the back if i were you...cause you'd mess up the brake distribution...once you get the knuckle assembly, all the rods and bars and links should just bolt on...you'd also need the ex parking brake line and discard the abs components
now...IMO...i think the drum brakes performs great if you arent running a whole lot of power...i upgraded my front brakes since they are the main ones...the back brakes are almost just assistant brakes =P IMO no need to be high performance
AccludePower
Oct 1, 2006 11:34 AM
Bendy817
Oct 19, 2005 07:39 PM
jusjermz
Oct 4, 2003 09:11 PM
