Honda S2000 Honda S2000
skunk 2 springs with stock ap1 shocks
Old Apr 27, 2007 | 05:02 PM
S2kGuy07's Avatar
Default skunk 2 springs with stock ap1 shocks
sup guys i just got a 01 s2000 and im wana lower it with the skunk springs..looked and found shocks for like 600 some bucks and thats crazy expensive. what do yall think about just usin the stock shocks?
Old Apr 27, 2007 | 05:51 PM
veilsides2000's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (S2kGuy07)
u can use the stock shocks
Old Apr 27, 2007 | 07:01 PM
m R g S r's Avatar
rides fine on stock shocks...i have that setup...go for it
Old Apr 28, 2007 | 10:31 AM
s2kdre's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (m R g S r)
i had skunk2's and my l/f strut blew out in a week, my car was pretty low with those springs.
Old Apr 28, 2007 | 12:31 PM
2+2=5's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (s2kdre)
instant of asking go or not, check out the difference in spring rate.
if that doesn't sway your urge to get those, check out how would the ride suffer when you put the damper out of optimized operating height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">u can use the stock shocks </TD></TR></TABLE>
that's of course, you can use ebay crap o spring on stock shocks too, but the bigger question is that do you want to do that.
if you just want it to look slammed then go for it, take strong note on negative affect on ride/handling
Old Apr 28, 2007 | 03:23 PM
S2kGuy07's Avatar
ya true
Old Apr 28, 2007 | 04:18 PM
m R g S r's Avatar
i have them they ride fine doesnt bounce handles just as well as stock IMO. . . .
Old May 3, 2007 | 07:44 AM
turbcivicgsr's Avatar
do you know if they eat through tires like a son of a bitch, because i dont want that. im sure they throw your camber off a little, but enough to buy new tires every week??
Old May 3, 2007 | 09:12 AM
b20integrapower's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (turbcivicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbcivicgsr &raquo;</TD></TR><TR><TD CLASS="quote">do you know if they eat through tires like a son of a bitch, because i dont want that. im sure they throw your camber off a little, but enough to buy new tires every week??</TD></TR></TABLE>
the car has neg. camber from the factory, im not too sure how much worse it gets with skunk2's. its probably not all that noticeable.
Old May 4, 2007 | 06:26 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: skunk 2 springs with stock ap1 shocks (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">
the car has neg. camber from the factory, im not too sure how much worse it gets with skunk2's. its probably not all that noticeable.</TD></TR></TABLE>
Camber only minimally affects tire wear unless you're doing burn outs. The S2000 is VERY prone to toe change, however. Toe will eat tires in a copule of days if its off by even a few degrees. Once you lower it, get it aligned for toe. You can correct camber if it makes you feel warm inside, too. It has adjustments for camber...you wont get it back to stock trim, though, but if it makes you feel better, get it as close as you can. I run neg.2.25 front and neg.2.5 rear. No inside tire wear issues, although the S2000 does have an agressive toe setting for the rear...stock...which makes your tires wear out on the inside stock as well.
Toe is your tire's enemy, but when tuned correctly can be one of the most if not THE most helpful angles when it comes to performance or driveability.
I have the skunk2 stock shock combo on my car too. It rides fine. The S2000 came with nitrogen filled performance dampers from the factory, with a rear external reservior ,so they can take a little more abuse, and are less prone to damper fade. I will be tracking the car on my setup for the first time tomorrow. I tracked the car when it was stock, so i can tell you after this weekend how the skunk setup compares. Seems to handle better on the street, however. BUT IT IS DIFFERENT. People confuse "different" for "worse" a lot, and its annoying. Adjust your driving style, and GET AN ALIGNMENT . The toe setting is very important in a sensitive beast like the S2000.
Old May 4, 2007 | 06:29 PM
B serious's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">instant of asking go or not, check out the difference in spring rate.
if you just want it to look slammed then go for it, take strong note on negative affect on ride/handling</TD></TR></TABLE>
Good points, and i understand what you're trying to say. But trust me, its really not that bad on an S2000. The stock dampers have a pretty high limit as to how much crap they will take before they give up.
The car is a little over lowered....but it looks good, and if you are a good driver and can adjust your driving style, it will definitely handle better than stock. Mine does. Cuz im a superstar!! lol.
Old May 5, 2007 | 05:38 PM
B serious's Avatar
Default Re: skunk 2 springs with stock ap1 shocks (B serious)
Well, just got back from the track this afternoon with the skunk2, stock shock setup. Worked out pretty damn well. Handles better than stock, BUT takes a lot more effort to keep the car behaving well. The onset of oversteer is more severe, and more unpredictable. The car half-spun on me. However, my rear tires were replaced at the stealership with NON PERFORMANCE all season peices of crap. My friend was the same suspension set up but on (rear) G-force sports on his stock wheels with stock sizes...and he did a lot better than me. He would get away from me about 4-5 car lengths or more after some consecutive turns. North track at autobahn is really really technical...so there's a lot of tossing going on. G-force sports are pretty decent good bang for the buck tire, but they're not the greatest, either.
I think that the SKUNK2, stock shock combo is really good, especially for the price.
do it.
Old May 6, 2007 | 06:19 PM
gpsports2k's Avatar
if you wanna go even lower....koni's have a higher and lower perch
Old May 8, 2007 | 03:15 PM
mugencivic99's Avatar
i did it on my stock shocks with skunks rides just like factory.. worked great for me
Old May 8, 2007 | 04:09 PM
s2k_jay's Avatar
it works great,but remember the one w/ most coils goes in the front or eles you'll be putting it backwards like me..
Old May 9, 2007 | 07:51 AM
B serious's Avatar
Default Re: (s2k_jay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k_jay &raquo;</TD></TR><TR><TD CLASS="quote">it works great,but remember the one w/ most coils goes in the front or eles you'll be putting it backwards like me..</TD></TR></TABLE>
no its the one with the most coils in the back, i think. It's the THICKER/STIFFER ones in the back. I was pretty sure that they were the ones with the most coils too.
Old May 9, 2007 | 08:01 AM
Archibalds_Puppet's Avatar
Default Re: (B serious)
They aren't labeled?
Old May 9, 2007 | 08:10 AM
B serious's Avatar
Default Re: (Archibalds_Puppet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archibalds_Puppet &raquo;</TD></TR><TR><TD CLASS="quote">They aren't labeled? </TD></TR></TABLE>
lol nope I had to speak to a skunk2 tech.
Old May 9, 2007 | 04:13 PM
I bought the Skunk2 springs and installed them. I like them alot but it seems like the front isnt lowered that much, anyone els notice this? The back sits a little lower then the front, right&gt;&gt;&gt;?
Old May 9, 2007 | 04:35 PM
s2k_jay's Avatar
oppss..yea the most coils one goes in the back i mean
Old May 9, 2007 | 04:36 PM
s2k_jay's Avatar
and you probably put them backwards just like me..
Old May 10, 2007 | 08:16 AM
the instructions that skunk2 sent me say that i need to put the springs with the most coils on the front, i can send them to anyone who needs them. i called skunk2 and they sent me the instructions.
Old May 10, 2007 | 08:50 AM
tuan...'s Avatar
so most coils in the front or back?!?!??! im getting mine in friday..
Old May 10, 2007 | 09:58 AM
m R g S r's Avatar
Default Re: (turbcivicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbcivicgsr &raquo;</TD></TR><TR><TD CLASS="quote">the instructions that skunk2 sent me say that i need to put the springs with the most coils on the front, i can send them to anyone who needs them. i called skunk2 and they sent me the instructions.</TD></TR></TABLE>
huge debate about this on s2ki.....
More coils in the rear....trust me i had em both ways....
here is with 9 coils in the front: (front is higher than the rear....INCORRECT!)
NOW here is with more coils in the rear: Sits better, headlights are aimed correctly, not aimed up blinding other drivers etc....
Old May 10, 2007 | 10:47 AM
i do agree that looks much better. im just telling you what the instructions said that skunk2 themselves told me. One of the only reasons im not happy with the springs is because of the difference i have in ride heighth. Do you think it makes a difference in handling when you put the more coils in the rear.
