h22 swap
i had a swap done h22 into 93 accord EX i keep getting a tps trouble code (code 7) i changed the tps sensor three times any suggestions on how to solve this problem
when you changed the TPS, did you make sure that you calibrated it? it has a little play when putting it on there.
I think its like .45 volts when throttle is CLOSED.
I would double check.
hondasport2000
May 1, 2006 03:51 PM
hondasport2000
Apr 24, 2006 11:12 AM
