what swaps can or can not i get bard or smog? into ef hb n da
Old Apr 27, 2007 | 02:01 PM
projectef's Avatar
Default what swaps can or can not i get bard or smog? into ef hb n da
im doing a couple of swaps for my buddies, n i was wondering which swaps i can get bard or smog.
1st swap - ls/vtec into 90 integra. obd2 ls block wit b16 head. im leaving it obd0, can i bar it or i have to use the obd0 b18a block?
2nd swap - 92 d16z6 into 90 ef. i converted it to obd1, can i still smog the car or i have to get it bard?
(we got alot of krooked *** ****** cops here)
Old Apr 27, 2007 | 03:27 PM
RSZero1's Avatar
Default Re: what swaps can or can not i get bard or smog? into ef hb n da (projectef)
LS/VTEC is a big no no. Here in cali at least, they do not like the mix and matching of heads. If you did it, you would have to do an LS swap, get that BAR'd then do the head swap.
Old Apr 27, 2007 | 09:16 PM
projectef's Avatar
so i can still get it bard if i use the b18b block in the 90 integra?
Old Apr 27, 2007 | 09:49 PM
FotoGenetix's Avatar
Default Re: (projectef)
whatever swap you get id do what i can to get it BAR'd just makes things easier. i know there are such things as mobile smog check points nowadays. ive seen a cop just direct a car over because it looked modified or is of a considerable age. the mobile smog check point would do it right then and there.
Old Apr 28, 2007 | 06:09 PM
projectef's Avatar
what is a mobile smog check point? is dat where dey take a look at it b4 u go n do ne thing?
Old Apr 28, 2007 | 10:27 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">what is a mobile smog check point? is dat where dey take a look at it b4 u go n do ne thing?</TD></TR></TABLE>
umm it was just explained
C_R_X_
Mar 27, 2009 08:28 AM
projectef
12
Apr 30, 2007 09:37 PM
k20o2o4civic
Jul 15, 2006 12:25 PM
gumbybum
Mar 19, 2003 07:22 AM
IgniteTeg
Jun 4, 2002 04:06 PM
