How to install review glow on a 99 civic HB with EX cluster
Old Apr 27, 2007 | 01:37 PM
huumanshadow's Avatar
Default How to install review glow on a 99 civic HB with EX cluster
First off thanks to everyone who help on my question about can i install a a EX cluster on a DX, should of done search first and not waste ppl time, sorry about that. So i got an EX cluster (YAY). Now how do i install those reverse glow that light up the entire panel? for sure talking the clear plastic cover off, but is there any additional wiring? because the glow gauge seem to need more power then the stock, just wondering where would i plug them into. cuz the item said something about wiring, power inverter, on off switch??
http://cgi.ebay.com/ebaymotors...wItem
Old Apr 27, 2007 | 01:44 PM
BlueIntegraBoy's Avatar
Default Re: How to install review glow on a 99 civic HB with EX cluster (huumanshadow)
Each gauge connects to an invertor. The invertor wires up to headlight switched 12v and ground.
You slide the needle through the gauge face hole after removing the stock gauge face screws.
Old May 4, 2007 | 10:14 PM
Default Re: How to install review glow on a 99 civic HB with EX cluster (BlueIntegraBoy)
Hmm, i see the invertor connect together, but where is the headlight switched v12? also can you recommend a good ground area?
Old May 4, 2007 | 10:33 PM
CarbonizedDX's Avatar
Look on the back of the gauges, you will see where the gauges actually screw into the cluster, there will be three/four screws (depending)...... one will be marked ( - ), this is your best ground. As for your 12volt for lights, tap into the solid red wire #12 on the far left plug that plugs into the cluster above the tach, here's a pic:
Jdmglenn
Sep 1, 2008 09:30 PM
watacivic
13
Oct 17, 2002 11:20 AM
Tofurky
Aug 27, 2002 10:24 PM
