dizzy swap question
They have the same internals so I would assume it'll work, but you may have to modify the housing...Using it the other way around, you have to cut 1 or 2 ears (mounting) to fit it on a B16. You seldom see it done like you're asking, because the B16 dizzy is more expensive than the D16a6...You're probably better off sourcing the right dizzy and sell the B16 outright.
the only thing i found here is a b16a dizzy, nothing else, so i guess i'll use it then, thank u, but i'm gonna use it on my d15b vtec cuz i cut on of the legs on the d16a6 dizzy to fit it in the d15
