another wiring/connector question
Old Apr 27, 2007 | 12:43 PM
blinger's Avatar
Default another wiring/connector question
y7 with a y8 head on it...wondering where this plug goes to and if i need it
the plug is green
Modified by blinger at 2:00 PM 4/27/2007
Old Apr 27, 2007 | 01:29 PM
Slurp56's Avatar
Default Re: another wiring/connector question (blinger)
Looks like VTEC Pressure switch to me. Depending on the ECU you use, you'll need it.
Old Apr 27, 2007 | 01:38 PM
blinger's Avatar
Default Re: another wiring/connector question (Slurp56)
i'll be using a PM6 ECU
Old Apr 27, 2007 | 01:39 PM
harmonator84's Avatar
I thought it was something to do with oil pressure...Something only used in OBD1+.
Old Apr 27, 2007 | 01:53 PM
blinger's Avatar
Default Re: another wiring/connector question (harmonator)
yea I believe its a oil pressure switch of some sort
Old Apr 27, 2007 | 01:54 PM
HondaPartsHero's Avatar
Technical Hero
its the VTEC oil pressure switch. you won't need it unless you are using a VTEC ECU (P28, P30, P72, PR3, PWO, etc). It was used on OBD0, OBD1, and OBD2 (excluding most JDM OBD2 engines)
Old Apr 27, 2007 | 01:59 PM
Slurp56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">i'll be using a PM6 ECU</TD></TR></TABLE>
You wont need to wire it up with that ECU. What are you using to control VTEC engagement?
Old Apr 27, 2007 | 02:27 PM
blinger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 &raquo;</TD></TR><TR><TD CLASS="quote">
You wont need to wire it up with that ECU. What are you using to control VTEC engagement?</TD></TR></TABLE>
turbo edit
Tripper13
Oct 24, 2015 06:07 AM
rockinTheDOHC
Mar 30, 2007 03:11 PM
EK FLY
Apr 14, 2005 08:35 AM
JinDIESEL
Sep 28, 2004 05:46 AM
JSPECHB
Feb 12, 2004 03:19 AM
