95 GSR OVER HEATING!!
Old Apr 27, 2007 | 12:18 PM
monkeyboy313@hotmail.com's Avatar
Default 95 GSR OVER HEATING!!
here is the situation. I have a 95 gsr, just put new head gasket, different block, and still haveing same issue.
Ever sence iv owned the car (5) months, i have had a bog issue. From 1k till 5k v-tec its a dogg. After v-tec its hold on for dear life. The car has 200psi compression, and idels helthy. Both my timing's was set right by Acura here in salem. My cluster gauge always says my heat is in the middle, wich is when my fans finlay kick on.... i would beleave is okay? I have removed the Therm. and run 50/50 fluid. I have changed my sensor thats on my water jacket and had no change in proformance.
My car dose run fine, an pepy when it first starts up like any other B18C1. But once it reaches the middle of my Temp gauge...it gets WAY sluggish. Even bogs, but never cuts out.
I need some info from some HT experts. Im truly stumped.
QUESTIONS-
1) where is the relay located?
2)is there any other sensor's that would trigger the fan to kick on earler & where?
3)Dose this sound like the motor is simply over heating?
4)Should i replace my head gaskit, reserface my head?
I think my valve guids might be going out b/c it dose bun a little oil, and will be replaceing them soon. BUT i have had this same head on a different block and had the same issue sence i bought the car. Can anyone shedd some light on this problem?
thanks, i did research this for almost a week on honda-tech and still could not find the right answers.
any help, ideas, thoughts would be great.
Old Apr 29, 2007 | 09:17 PM
Default Re: 95 GSR OVER HEATING!! (monkeyboy313@hotmail.com)
BUMP!!
my car was throughing a code 6. I am replaceing that part tomarrow.
I have some more questions, like could having the wrong distributor maybe cause my car to run like this?
Again, my motor feels like it falls on its face from 1k to 4k.
My car is a 95gsr, with a 95 harness and ecu, with a obd0 b16a head. Its a 1st gen head. I beleave its the same distributor that came with the car.
Maybe i need a 95 gsr dizzy?
What about advancing my timeing? Wich way do i turn it to advance?
Maybe i need to advance my cam's??
Any info would be great!
Old May 8, 2007 | 12:53 PM
bump!!!!
Old May 8, 2007 | 12:56 PM
1.8L_allmotormilitia's Avatar
maybe the block has bad cylinder walls or cracked?? did you install head gasket the correct way? but from what i remember my integra temp. was about at half way. the bogging could be running rich or bad timing?
Old Feb 14, 2010 | 04:03 PM
Jester562's Avatar
New User
I had the same problem but i didnt replace the cylinder head gasket yet im not sure if theres a crack i have to go to the machine shop for them to check it. oh yah one thing i went to a mechanic he said the bad cylinder gasket and the something about the cooling system
jonyb
Nov 30, 2006 06:15 PM
enhancedCL9
Oct 20, 2005 01:28 AM
hotintegranights
Aug 9, 2003 06:16 PM
