Weird hissing after engine shuts off B20 DA
Old Apr 27, 2007 | 08:50 AM
smokey_the_ek's Avatar
Default Weird hissing after engine shuts off B20 DA
Okay so my buddy has a 92 teggy with a B20 swap, integran intake manifold on it. Has a short ram on it too. So i know that it is not the intake pipe because i know what that sound is, this one is coming from the driver side of the intake manifold. It is not a deep sucking sound like that of the intake, more of a soft hiss. When we turn it off you can hear the suction of the intake, once that has stopped you can hear a leak of some sorts, like air from a tire. Any idea to which possible vacume hose it could be'??? I have checked the ones coming from the map sensor, also the one coming to the top of the fuel pressure regulator. Any suggestions would be great!! thank-you in advance.
Old Apr 27, 2007 | 09:11 AM
im_poor's Avatar
Default Re: Weird hissing after engine shuts off B20 DA (smokey_the_ek)
if its a vacuum leak your idle would probably jump up and down......
correct me if i'm wrong.
Old Apr 27, 2007 | 01:38 PM
Default Re: Weird hissing after engine shuts off B20 DA (im_poor)
well the idle does go wonky sometimes. But at other times its fine.
Old Apr 27, 2007 | 02:04 PM
CompanyFlow's Avatar
I have the same noise. I dont pay any attention to it. It couldnt be a vacuum leak because the car is off.
76 camaro car
Oct 7, 2014 02:18 AM
rude_88
Aug 6, 2010 09:13 AM
deadmemoryy
Dec 12, 2007 08:24 PM
Integra4lyfe069
Mar 10, 2007 08:58 PM
carracr625
May 25, 2005 06:14 PM
