Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
seized engine? maybe?
Old Apr 27, 2007 | 08:09 AM
bgx9ner's Avatar
Default seized engine? maybe?
my ISUZU passport had an oil leak and i think the motor seized. but the other day i filled it back with oil and it started up for lik 5 seconds. but then seized up again. i then took out the spark plugs and sprayed some good lubricant in the cylinders. now i'm just waiting the day out and i 'll check it again. it can't be too bad of shape if it ran for 5 seconds right? also when i took out the spark plugs, they were dripping with oil! what could of happen?whats your guys opinion and what else should i do cause replacing the motor is too damn expensive. if it comes to it what motor will fit into a 97 passport anyways. thanks.
Old Apr 28, 2007 | 05:27 PM
Ross 2.0's Avatar
In a Junkyard near you.
sounds like the motor seized. My best advice is to buy a real honda and you won't have that problem anymore
Old Apr 29, 2007 | 10:17 AM
bgx9ner's Avatar
Default Re: (ScruffyTheJanitor)
true true i know i got got 2 acuras but i really need to fix this passport. its summer and thats my camping car ya know. please help
Old Apr 30, 2007 | 04:41 PM
Ross 2.0's Avatar
a seized engine is very hard to repair. That involves a full rebuild, and still the engine may not be able to be salvaged.
Try to turn the engine with a breaker bar at the crank pulley.
Old May 4, 2007 | 08:15 AM
bgx9ner's Avatar
ya for real. i just want to give it a try to fix it but if not then i'll have to replace the motor. just that its so hard to get that engine and it'll be spendy when i find one. i just want an suv right now!
Old May 4, 2007 | 10:54 AM
civicandy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScruffyTheJanitor &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the motor seized. My best advice is to buy a real honda and you won't have that problem anymore</TD></TR></TABLE>
For the record, the motor in the Izuzu Rodeo is the honda motor from the Honda Passport. Entire vehicle is the same, only slightly stripped down compared to the Honda. Did it run out of oil or was the oil pump bad?
Old May 5, 2007 | 11:26 AM
70hphf's Avatar
That's a GM engine in those piece o *****....
Modified by 70hphf at 5:39 PM 5/5/2007
Old May 6, 2007 | 12:31 PM
bgx9ner's Avatar
Default Re: (civicandy)
it ran out of oil. the thing that gives me some hope of reviving it is that it started and ran for a few seconds then seized up again. i'm in the process of looking for a new motor. if i can get parts and labor for under 2500 then i'll do it. whats a fair price for a motor swap?
Old May 6, 2007 | 04:54 PM
70hphf's Avatar
It may be a dumb idea, but dump 5 quarts in it and try to start it. May save you some $$.
Jabinya
Mar 25, 2008 05:20 PM
DA9_DAD
May 5, 2007 12:24 AM
trustbuddy
Jan 14, 2006 08:27 PM
Hyb
Mar 23, 2005 07:04 PM
gaydm.accord
Dec 10, 2003 12:13 PM
