91 crx si MC questions!!
Old Apr 26, 2007 | 09:49 PM
1_slow_crx's Avatar
Default 91 crx si MC questions!!
and by MC i mean the brake master cylinder...
okay so i have integra front caliper, and my pedal isnt as stiff as it used to be, so i though why not get the 91' civic EX 15/16 MC . so i go to pull mine out and right on the side its says 15/16! ...
Correct me if im wrong but crx si 91' stock one is 7/8... correct?
if so .. the pervious owner must have changed it to the bigger 15/16 without even knowing it. But why is my pedal travel so far then? idk im going to bleed them all around and see if it gets any better.
Or maybe the crx si does come with a 15/16 and the one on the civic EX for some reason is better... IDK..
help me out tho thanks!
Old Apr 27, 2007 | 12:48 AM
abnaasefmb's Avatar
Default Re: 91 crx si MC questions!! (1_slow_crx)
yeah try bleeding them, you can adjust the pedal hight but it is a pita!
Old Apr 27, 2007 | 04:05 AM
1_slow_crx's Avatar
Default Re: 91 crx si MC questions!! (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">yeah try bleeding them, you can adjust the pedal hight but it is a pita!</TD></TR></TABLE>
well its not the height thats a problem but how soft the feel is..
Old Apr 27, 2007 | 10:20 AM
1_slow_crx's Avatar
Old Apr 27, 2007 | 08:11 PM
1_slow_crx's Avatar
????help
Old Apr 27, 2007 | 10:52 PM
Bob_760's Avatar
Have you bled the brakes? Are there any problems with any of your Calipers?
If your brake pedal is feeling soft chances are adding/bleeding/changing (whatever the case may be) the fluid will take care of it.
Old Apr 28, 2007 | 03:07 PM
1_slow_crx's Avatar
Default Re: 91 crx si MC questions!! (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">Have you bled the brakes? Are there any problems with any of your Calipers?
If your brake pedal is feeling soft chances are adding/bleeding/changing (whatever the case may be) the fluid will take care of it.</TD></TR></TABLE>
maybe this MC is just weak.
i have new integra front calipers.
the MC looks new-ish and i bleed the whole system as best i could.
dankimber
Mar 14, 2011 03:45 AM
littlecrxVTEC
May 14, 2007 01:47 PM
AgentJam
Mar 2, 2005 08:53 AM
blackccoupe
Oct 29, 2003 07:52 PM
polycrx
Feb 15, 2003 03:51 PM
