trying to swap b18a1 motor in 89 hf crx
The harness is messed up on the 89 crx hf, body is clean. Is the 90 honda civic si dash harness the same as the 90-91 honda crx si dash harness?? Please help guys, its so damn hard to find a hf harness. What needs to be done to modify the si harness to work on hf??
what exactly is the problem with your old harness? if its just the dash harness you should be able to unwrap it and trouble shoot your problem. Thats what i did with my hf harness so it was cleaner(nothing that i didn't need, racecar) it takes a bit of time and it is VERY intimidating when you begin, but after you start figuring things out, its really pretty simple.
as far as the SI dash harness, im pretty sure it is the same, but im not telling you to buy one until someone else can tell your for sure.
the hf dash harness is cut all over the place, looks like **** and they used house wires speaker wires for the engine hf harness. Looks like ****
lunalink
11
Feb 26, 2010 12:56 PM
Boost Junkie 83
16
Apr 2, 2007 06:28 PM
