Gauge cluster not working?
As title states, my entire gauge cluster is not working. I have checked ALL fuses in the various fuseboxes (INCLUDING problematic #15). I'm pretty lost as to where to go from here, all visible connections seem secure and all fuses are A-ok.
Any help is appreciated!
Nope, it just up and stopped working yesterday after I replaced a couple fuses in the under-dash fusebox. I didn't work behind the dash at all, I'm stumped.
Where would I check for the appropriate ground?
I know in the EGs, there's a ground connected to the dash bracket on the right hand side behind the cluster. I assume there's one there for an Integra.
Perhaps you shorted something when you replaced the fuses. I guess double check all the connections going into the fusebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Was that why nothing was working or a result of why nothing was working?</TD></TR></TABLE>
I couldn't tell you, I cant figure out this problem. Once the battery was recharged the gauges still didn't and currently don't work.
These are NOT aftermarket guages, I haven't touched the stocks and dont plan on it unless I go FI in the future.
Can anyone hop out of a picture thread and throw their .02 in?
I guess you can check if you are getting any power to the cluster itself. Check out the first link in my signature to check which wire gives power.
CMCivicSI
May 20, 2004 04:24 PM
